The OEM seperator has a mounting bracket that bolts to the fuel pump (pull the front F.P. bolt and pass it through the bracket). 5/16" rubber fuel line up top, 5/16" to fuel pump steel line, and 1/4" to return line.
If you buy a repop seperator get a good one- they sell units where the internal lines are not of the correct length. And the 1/4" orifice has to be of a certain size or can cause pressure drop. I had to alter the one I bought.
I have a spare pump to seperator steel line with pump fitting if you need one.
