Help with engine running very rich #1815763
04/30/15 08:20 PM
04/30/15 08:20 PM
clarks summit pa
73cuda340 Offline OP
clarks summit pa
I have a Ray Barton 528 hemi in my cuda and the car runs so rich to the point that where my eyes burn real bad if I stand next to the car for more than a minute. The motor has less than an hour of run time since I bought it. It has two edelbrock performer 600 cfm carburetors and they were setup when the car was dyno tuned. Brand new msd distributor with 6al box and edelbrock performer mechanical fuel pump. Fuel pressure is 7-7.5 psi. The car ran fine last fall and I went to start it up to get it ready for the summer and it is running like absolute garbage now. My first thought was the gas went bad over the winter so I drained the whole system and filled it up with fresh gas with no luck. I have to give it gas to keep it running and it acts like it is loading up when I rev it. There aren't any vacuum leaks anywhere that I can find. Is it possible that the fuel pressure is too high and pushing past the needle and seat and just dumping into the motor? This is already the 3rd fuel pump that I had to put on this motor as the first two were bad right out of the box and were putting out 9 psi and flooding the motor. Any help would be greatly appreciated.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip, (JA5) Silver Frost Metallic 1973 Challenger Rallye 340 1985 W150 Power Ram prospector 1986 Camaro IROC-Z 305 tpi
Re: Help with engine running very rich [Re: 73cuda340] #1815766
04/30/15 08:23 PM
04/30/15 08:23 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
What fuel pump? Should only be about 6 psi.
Re: Help with engine running very rich [Re: ademon] #1815773
04/30/15 08:32 PM
04/30/15 08:32 PM
clarks summit pa
clarks summit pa
Mechanical Edelbrock performer. The description for the pump says it makes 6 psi max and the first two made 9 and the last time I ran the car it was at 6 but now it is a little over 7.
Re: Help with engine running very rich [Re: 73cuda340] #1815790
04/30/15 08:51 PM
04/30/15 08:51 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
http://www.edelbrock.com/automotive/mc/carburetors/pdf/carb_owners_manual.pdf
Page 5 gives fuel pressure specs, says to set it at 5.5 psi at idle.
Being a dual quad setup you probably will need more volume but not more pressure than a single setup.
I've also seen the brass float get pinhole leaks over time and start sinking. Make sure your needle and seats are not leaking by.
Don't be the exception.
Re: Help with engine running very rich [Re: 73cuda340] #1815818
04/30/15 09:26 PM
04/30/15 09:26 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
If your using a fluid filled gauge near engine heat it might not be accurate.
Re: Help with engine running very rich [Re: ademon] #1815835
04/30/15 09:50 PM
04/30/15 09:50 PM
usa
smos001 Offline
smos001  Offline
usa
I bought an Air Fuel Ratio gauge for my 70 Challenger. Best money I ever spent on a gauge. I now can tell the AFR at every level of load etc.
It sure beats pulling the spark plugs out and checking.
Re: Help with engine running very rich [Re: 73cuda340] #1815842
04/30/15 09:59 PM
04/30/15 09:59 PM
IL . usa
cjs69mope Offline
cjs69mope  Offline
IL . usa
First i would get a simple spark tester that is adjustable and can read the kv output of the the spark i have one in my tool box .
MSD should jump a blue 1 inch long spark no problem . 45kv no less.
second you could take a flash light and look into the throtle at the main boosters to see if it is dumping fuel there should be no droplets coming from the boosters under say 2800-3000 rpm .
If you see the boosters dribble fuel at idle then floats set to high or fuel pressure to high.
third 7 psi is not that high but i would follow the Edelbrock recommendations. Do you have a fuel pressure Regulator?
IF no i would get one! and set the pressure where you want it.
Also you can use a timeing light to see fuel spray coming from the booster in the carb throat while increasing the RPMs.
Also could the timing have changed ?
that motor prob likes 18 to 20 deg initial at say 1000 rpm and 34 total all in at 2000-2200 rpm.
I would start with this .
1969 Dodge Charger 1969 Dodge Superbee
Re: Help with engine running very rich [Re: cjs69mope] #1815889
04/30/15 10:55 PM
04/30/15 10:55 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Pretty much what's been said above:
#1. Fuel pressure (if accurate) is too high, 6-6.5 max.
#2. Float level too off, Carters/Edelbrocks need to be set right, also look for a sunk float, even brand new ones sometimes have tiny pinholes, also bad gas can easily clog a needle & seat open overfilling the bowl.
#3. Vacuum leak somewhere, Hemi's like to suck intake gaskets, hard to find but very common.
twocents
Re: Help with engine running very rich [Re: ScottSmith_Harms] #1815913
04/30/15 11:28 PM
04/30/15 11:28 PM
clarks summit pa
clarks summit pa
The gauge is not liquid filled, however I don't have another gauge to compare it to for accuracy. I didn't install a fuel pressure regulator because when I called edelbrock about the problem with my first two pumps, I was told that I didn't need a regulator with that pump and that there was no way to adjust the pressure of the pump. I didn't install a regulator after that either because I figured it would only be masking the problem of the pumps being that they are only supposed to make 6 psi max and not 9. I will try to get a helper tomorrow to keep it running so that I can look down the carburetor and see whats going on.
Re: Help with engine running very rich [Re: 73cuda340] #1815915
04/30/15 11:31 PM
04/30/15 11:31 PM
clarks summit pa
clarks summit pa
I don't have a tester to measure the output of the spark, but when I pulled a plug and cranked the motor over I had very strong spark.
Re: Help with engine running very rich [Re: 73cuda340] #1815937
04/30/15 11:51 PM
04/30/15 11:51 PM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
I'm betting on a float or needle & seat issue.
It's Swifty! Swifty, you toad sucker!
Re: Help with engine running very rich [Re: 73cuda340] #1816025
05/01/15 01:28 AM
05/01/15 01:28 AM
hooziewhatsit Online content
hooziewhatsit  Online Content
Are the rods being pulled down at idle? They should be.
open the star screw (two of them) on top of each carb, and rotate them a bit to see the enrichment rods.
Re: Help with engine running very rich [Re: 73cuda340] #1816147
05/01/15 09:41 AM
05/01/15 09:41 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Put new spark plugs in it, then see how it runs.
Re: Help with engine running very rich [Re: hooziewhatsit] #1816148
05/01/15 09:42 AM
05/01/15 09:42 AM
Cincinnati, Ohio
Cincinnati, Ohio
This too.
Re: Help with engine running very rich [Re: 73cuda340] #1816182
05/01/15 10:47 AM
05/01/15 10:47 AM
MD
p d'ro Offline
p d'ro  Offline
MD
Did you have the same gas in it all fall/winter with no stabil? I was told it had shelf life of 30 days. You may have goo in your bowls/needle/seat. Any gas coming out of the primary vents or do you see fuel wetness on top/around the carbs?
Re: Help with engine running very rich [Re: 73cuda340] #1816183
05/01/15 10:51 AM
05/01/15 10:51 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Since it ran fine before parked and now runs rich, the bad gas scenario is most likely the culprit. Time to open it up and see what's going on inside, having a buddy "look down the carb" isn't going to get you anywhere.
Re: Help with engine running very rich [Re: ScottSmith_Harms] #1816666
05/01/15 09:05 PM
05/01/15 09:05 PM
clarks summit pa
clarks summit pa
The metering rods are down during idle as far as I can tell and I took a look down the carburetor while it was running and gas was pouring out of the boosters so definitely either the needle and seat or fuel pressure. . Im going to pick up a regulator tomorrow and try that next.
Re: Help with engine running very rich [Re: 73cuda340] #1816738
05/01/15 10:57 PM
05/01/15 10:57 PM
Cincinnati, Ohio
Cincinnati, Ohio
Did you loosen the screw and slide the cover off to the side so you could see the rods with the motor idling? Rev it just a bit and watch them jump up?
I have been using 600 like yours since like 1985. Been on every 340 I ever had at one point or another. I have tuned it quite a lot since I trailer it on vacations all over the country including driving it to the top of Pikes Pike twice. They got to be lean to make up that mountain.
Anyway just recently put a temporary fuel gauge on my mechanical fuel pump equipped 340 and had 6-8 PSI depending on RPM and throttle position.
My car also has the hemi vapor separator mounted on the fuel pump connected to a factory 1/4" steel return line. It has a 3/8" suction line for the fuel pump. It was the first time I checked fuel pressure under load with the hemi VS/return line and I had plenty of pressure even under WOT. Been driving with this fuel setup for 10 years and 25K miles since 2007 on my most recent 340 with my trusty 1405 600 carb..
IMO 7-7.5 psi fuel pressure is not your problem.
What do the spark plugs look like? Get used to pulling them out, you need to keep track of them.
Re: Help with engine running very rich [Re: 73cuda340] #1817024
05/02/15 01:07 PM
05/02/15 01:07 PM
AndyF Online content
AndyF  Online Content
The Edelbrock carbs will get "eaten up" by the ethanol content in pump gas if they are allowed to sit for a long period of time. If you pull the tops off of the carbs you'll most likely find some white slime in the bowls. That slime gets into the fuel passages and blocks things up. My guess is that you're actually running lean not rich due to a blocked passage. People think the stinky idle is rich but typically it is dead lean and misfiring.
Re: Help with engine running very rich [Re: AndyF] #1817970
05/03/15 09:26 PM
05/03/15 09:26 PM
clarks summit pa
clarks summit pa
Ok, I will pull the top of the carbs tonight before I buy the regulator. Definitely running rich and not lean though with the amount of gas that was dumping into the motor.
