1970 Convertible Parts - Coronet
#1810768
04/24/15 09:42 AM
04/24/15 09:42 AM
Posts: 8,430 St Charles MO
70Coronet500Vert
St Charles MO
OK. I think this is the summer of installing the convertible top. I have owned the car over a decade, no top and have probably driven it 30 times.
If I say I want to replace "everything" except hydraulics (I already did that) does that make sense to a convertible parts supplier?
I want pads, cables, top, glass, weatherstrip, what else?
The top works good, so I will probably not remove it, I will paint it in place.
It looks like it is doable at home over a weekend, if you do not get frustrated tacking the top in place.
So, an adventure worth taking and what about the parts list? anyone done it?
No matter how responsible he may seem, never give your gun to a monkey! 1970 Coronet Vert 1972 Charger 1974 Satellite Sebring Plus Sundance 2001 Ram 4x4 2002 Intrepid 2006 300C
Re: 1970 Convertible Parts - Coronet
[Re: p d'ro]
#1811035
04/24/15 04:53 PM
04/24/15 04:53 PM
Andrewh
[Re: 70Coronet500Vert]
#1811036
04/24/15 04:55 PM
04/24/15 04:55 PM
Andrewh
#1815206
04/30/15 09:11 AM
04/30/15 09:11 AM
Posts: 1,756 London, England
Gavin
London, England
I think you had it in your post - it's a job that requires lots of patience and you need to be methodical. I've done it twice on my Challenger. the first one lasted well over ten years and was still absolutely fine but I changed it for a black one after the car was repainted. I've looked at a lot of professional installs over the years and to be honest I've seen many that were worse than mine. Not particularly down to my skill but having the time to be patient - tack it up, take 'em out, readjust, tack it again, etc. If your frame needs a lot of adjustment then that would add a lot to the difficulty/level of expertise. Make sure you have the measurement from the rear bow to the rear deck, that's a critical measurement, once you remove the old top it all sags down and you need to have that to know where to install the new top.
So, it's definitely doable, and also saves a lot of money. Be prepared that yes it could take a weekend, or could take a month of spare time.....
[Re: Gavin]
#1815767
04/30/15 08:23 PM
04/30/15 08:23 PM
Posts: 583 NJ
rth
NJ
I replaced the top on my '70 Coronet. I used the Bolig article mentioned above. Worked out well. It is time consuming and you definitely need patience. I would post a pic but haven't figured out how.
