Re: Cragar S/S wheels, is chrome any good?
[Re: maximus]
#1815825
04/30/15 09:34 PM
04/30/15 09:34 PM
Posts: 19,890 Puttin' on the foil in Charles...
not_a_charger
Mr. Big Shot Moparts Moderator
I bought a new set of Keystones (same company) a few years ago. The car sat outside in the summer for 2 months. It got rained on a few times. The wheels started to rust. No warranty for rust. I'll never buy another product from that company again.
Earning every penny of that moderator paycheck.
DBAP
[Re: Hemi Head]
#1815883
04/30/15 10:49 PM
04/30/15 10:49 PM
Posts: 15,976 Chilliwack B.C. Canada
RUNCHARGER
Those wheels did the same thing 45 years ago. Too bad they haven't put some effort into doing it right in all that time.
Sheldon
Sheldon
[Re: maximus]
#1816021
05/01/15 01:21 AM
05/01/15 01:21 AM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
The only problem with that, is you end up with the same quality of chrome outers again, as Carlstar/Cragar supply most other places with outers.
Not all of them of course, but quite a few. Getting raw ones and then having them plated might be a better way to go, just expensive is all..
There is another supplier that I have used, but with them you have to buy (from memory) a minimum of 20 pallets at a time of any one given size. Basically an entire run of any size you need.
[Re: OzHemi]
#1816033
05/01/15 01:41 AM
05/01/15 01:41 AM
Posts: 20,535 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
Yeah, if you did all that work and still ended up with their poorly chromed hoops then what would be the point? I know chrome shops won't do 2 piece wheels, but if you had money to burn you could buy a rusty set, take them apart, rechrome the centers and the hoops, and then ship them off someplace to have them jigged up and reassembled. Probably end up burning thru $1500.00 or more before you were done.
[Re: maximus]
#1816040
05/01/15 01:53 AM
05/01/15 01:53 AM
OzHemi
Garden Grove, CA
Guess it all depends on how much you like Cragars (and raw outers are pretty cheap at least.) Personally, I don't like them and rather go with an aluminum/billet/forged wheel. Polishing is easy after all..
[Re: OzHemi]
#1816266
05/01/15 12:51 PM
05/01/15 12:51 PM
Posts: 75,004 U.S.S.A.
JohnRR
U.S.S.A.
Weren't the wheels being disgused in the thread alum. center with a steel band or is that the Keystone Klassics only?
The classic/original S/S wheel is a composite steel/aluminum wheel as well... Are the current wheels the same way ?
[Re: OzHemi]
#1816414
05/01/15 03:20 PM
05/01/15 03:20 PM
Posts: 6,561 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
Yep..I ment the classic, in the sense of not like the 1 piece style ones someone posted a pic of.
The S/S is still like they were, chrome steel outer with a chromed aluminum center. Unrelated question: What exactly holds the 2 pieces together besides friction? I'm not aware of any welding rod that allows you to weld aluminum to steel. Kevin
[Re: OzHemi]
#1816511
05/01/15 05:19 PM
05/01/15 05:19 PM
Posts: 4,566 Motor City
6PKRTSE
Motor City
Mine rust when you sneeze near them.... Mine are even the older supposedly better quality chrome back then from the 80's. They have been off & on my car since around 1985.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: maximus]
#1816538
05/01/15 06:10 PM
05/01/15 06:10 PM
Posts: 5,161 CT
GTX MATT
CT
The chrome is garbage. I have a set that are a little over a year old. Out of the box you could see the copper in some spots. I put two coats of wax on them. By the end of the season you can see rust trying to pop through in a few spots. Polished them, 2 more coats of wax, and sat all winter. Keep alot of wax on them, it will help. It shines nice when its clean, but its definitely not good quality.
I figure when it looks like crap I'll send them someplace for good chrome.
[Re: GTX MATT]
#1816544
05/01/15 06:19 PM
05/01/15 06:19 PM
OzHemi
Garden Grove, CA
The chrome is garbage. I have a set that are a little over a year old... This one was about 2 days old.. right out of production to my hands nearly...
