440 not centered with radiator? #181502
01/02/09 12:59 PM
01/02/09 12:59 PM
Inver Grove Heights MN
74RR Offline OP
74RR  Offline OP
I swapped my 360 for a 440 now I notice that my fan is not centered with my radiator. Is this going to be problem?
Re: 440 not centered with radiator? [Re: 74RR] #181503
01/02/09 01:50 PM
01/02/09 01:50 PM
IL
furious70 Offline
furious70  Offline
IL
engines are offset a touch to the pass side for steering clearance....would have thought your 360 should have been similar.
Re: 440 not centered with radiator? [Re: furious70] #181504
01/02/09 02:29 PM
01/02/09 02:29 PM
74RR Offline OP
74RR  Offline OP
I might have been,I just never noticed it.Thanks.
Re: 440 not centered with radiator? [Re: 74RR] #181505
01/02/09 02:45 PM
01/02/09 02:45 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Did your 360 have a shroud? If it did you'll see the engine was offset....
Re: 440 not centered with radiator? [Re: furious70] #181506
01/02/09 04:19 PM
01/02/09 04:19 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
cut a hole in the middle of your hood and you'll see just how far to the pass side they are.
