I can't speak for the TCI unit, but the Silver Sport (formerly Keisler Engineering)unit I have installed, very straight forward install, .070 OD ratio, the 4L60E's overall profile is slightly smaller than that of a 727 so no trans tunnel mods needed, the factory kick down linkage is eliminated and replaced with a TV (throttle valve) cable, the transmission cooling lines (supplied braided SS) are now on the passenger side of the transmission, you combine them to your factory lines to complete the install, there is a module that needs to be wired to the transmission, very simple....I don't know if Silver Sport is offering any updated modules with dash control to tailor on the fly shift points, lock up, etc?...the stock program module with require a laptop interface if you desire to change the preprogramed performance settings...the install kits address the mods needed for console or column shifters (but check with Silver Sport before you purchase to check your application) you can retain your stock shifter set up for a "stock" look for most Mopar application, the kit is pretty much complete from bellhousing to driveshaft, and everything needed between, it's about a 4 hr install for the experienced mechanic
I'd recommend you talk to Jeff Kaufmann at Silver Sport for any questions about your application/needs, he's straight forward, no BS, if he can help you, he will
Mike
