440source: offset alum rocker arm kit. good choice?
#1813789
04/28/15 11:49 AM
04/28/15 11:49 AM
RapidRobert
3 bills. required for their bare super stealth heads. For a mild app (mild hyd non roller cam) are them a good choice? thank you for your time. EDIT do I need alum/roller rockers and do they make an iron offset rocker (for intakes) that would suit my needs which'd be cheaper (if I dont need the high dollar stuff) ?
Re: 440source: offset alum rocker arm kit. good choice?
[Re: cjskotni]
#1814220
04/28/15 10:36 PM
04/28/15 10:36 PM
RapidRobert
I think for a street motor where you won't be regularly pulling it to 6000+ RPM's with some super high lift cam, you'd be fine. Actually I was thinking the source' stuff was overkill for my needs & wondering if there was a cheaper option (such as offset steel/non roller? intake rockers). this is new territory for me so I dont know what is available. yes the SS heads are more intended for a race app than a DD (as far as I can tell) but that is the plan so far. If there are some cheaper options please holler & I will checkout Andys' site.
