Block O rings? #1814188
04/28/15 10:00 PM
04/28/15 10:00 PM
W. Kentucky
justinp61 Offline OP
W. Kentucky
How do I remove them, tried a pick at the joint but no luck.
Thanks.
Re: Block O rings? [Re: justinp61] #1814196
04/28/15 10:09 PM
04/28/15 10:09 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Are you trying to eliminate them or replace them
wave
Re: Block O rings? [Re: justinp61] #1814198
04/28/15 10:12 PM
04/28/15 10:12 PM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
When I decided to remove the O rings from my block I wanted to fill the grooves so I would have a good flat surface. I finally decided to use a large mill file and very carefully filed the rings down to block level. When finished you could not tell where the O rings were. This was several years ago and they still look great. Wouldn't hesitate to do it again.
Re: Block O rings? [Re: MR_P_BODY] #1814199
04/28/15 10:15 PM
04/28/15 10:15 PM
W. Kentucky
W. Kentucky
wave
Remove them. I'm planning on running a Fel-Pro 1008 gasket and don't need the o rings. Also I plan on having the deck fly cut to ensure they're flat.
Re: Block O rings? [Re: justinp61] #1814206
04/28/15 10:21 PM
04/28/15 10:21 PM
MR_P_BODY Offline
MR_P_BODY  Offline
wave
File them flush so it fills the groove
wave
Re: Block O rings? [Re: justinp61] #1814286
04/28/15 11:26 PM
04/28/15 11:26 PM
W. Kentucky
W. Kentucky
Will it cause any problems when milling the block?
Re: Block O rings? [Re: justinp61] #1814305
04/28/15 11:51 PM
04/28/15 11:51 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Let them mill it off
wave
Re: Block O rings? [Re: justinp61] #1814385
04/29/15 01:49 AM
04/29/15 01:49 AM
I have used a small pointed punch to start the O ring to back up from the joint, tap gently and once the wire is making a V or U grab it and pull it out from there scope up IHTHs
