I have a pretty close to stock 440 six pack with an automatic and no stall converter. Yesterday I took the car for the first time out an took 2 lobes off the MP purple Cam and wrecked 2 lifters. I don't know any history on the motor build other that it sat a long time. I don't have much confidence in choosing a new cam and lifters for this motor, just want it to be powerful yet street able with the automatic.
Brent
Did you do some sort of pre start lubing procedure?
Like:
-pre-lube the motor like it was a fresh start up through the distributor.
-While doing that spin the motor and check is the valve train was getting oil
-Maybe put some additive in their too
I could have been worn before you even started it up. Might want to check seat pressures and size of valve springs.
