440 sixpack camshaft choices? #1813471
04/27/15 10:53 PM
04/27/15 10:53 PM
Wisconsin
71duster414 Offline OP
Wisconsin
I have a pretty close to stock 440 six pack with an automatic and no stall converter. Yesterday I took the car for the first time out an took 2 lobes off the MP purple Cam and wrecked 2 lifters. I don't know any history on the motor build other that it sat a long time. I don't have much confidence in choosing a new cam and lifters for this motor, just want it to be powerful yet street able with the automatic.
Brent
hoffmanhhr@gmail.com
Re: 440 sixpack camshaft choices? [Re: 71duster414] #1813629
04/28/15 01:38 AM
04/28/15 01:38 AM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
You should call Bob Karakashian aka Mr. Sixpack. He makes custom cams that are suppose to be real good for Sixpacks. I think his number is 248-477-7776. Some members are using his cams.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: 440 sixpack camshaft choices? [Re: 71duster414] #1813677
04/28/15 02:58 AM
04/28/15 02:58 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Brent
Did you do some sort of pre start lubing procedure?
Like:
-pre-lube the motor like it was a fresh start up through the distributor.
-While doing that spin the motor and check is the valve train was getting oil
-Maybe put some additive in their too
I could have been worn before you even started it up. Might want to check seat pressures and size of valve springs.
Re: 440 sixpack camshaft choices? [Re: autoxcuda] #1813754
04/28/15 10:44 AM
04/28/15 10:44 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
If you don't go with a custom grind and don't mind some adjusting from time to time a Mopar 528 solid works great w/ a stockish 6-pack. As mention you must use heavy amounts of break-in AND a can of Zinc additive at each oil change. Even with syntho oil.
Coming soon!!!!
Re: 440 sixpack camshaft choices? [Re: 70sixpkrt] #1813759
04/28/15 11:02 AM
04/28/15 11:02 AM
Wisconsin
Stewpar Offline
Stewpar  Offline
Wisconsin
X2 Bob is a great guy!!!!!
Admiration For Multiple Carburetor Vehicles...
Re: 440 sixpack camshaft choices? [Re: Stewpar] #1813782
04/28/15 11:35 AM
04/28/15 11:35 AM
Nebraska
70VcodeCoronetRT Offline
Nebraska
I have a Mr Six Pack cam as well. Just waiting for my block to get done at the machine shop. Heard nothing but good things about them.
