Originally Posted By sgcuda
Mobil 1 15w-50 synthetic since beginning. Hemi grind hydraulic, .590 purple shaft solid, Herbert roller. Never let me down.
Used to run Penn Grade 1, now I run the Mobil 1 and LOVE IT! Works exceptionally well for me in a street application with a filled block and handling/controlling oil temps much better then conventional or semi synth stuff
