Tech Tip- Cheap Gas Tank Siphon #1811584
04/25/15 02:49 PM
04/25/15 02:49 PM
Philadelphia PA
Pynzo Offline OP
Drugs are bad
Pynzo  Offline OP
Drugs are bad
Philadelphia PA
I needed to pull out a POS chinese tank sender I installed last year and wanted the tank as dry as possible before I lowered the tank.
Bought this $8 hand siphon from Jegs and the hose was too curly to do what I wanted, so I pulled the ground wire from a piece of Romex cable I had laying around and inserted it into the hose. Stays nice and straight now and with the filler neck pulled out of the tank can reach every spot that gas pools in bottom of the tank. She's bone dry now-
Re: Tech Tip- Cheap Gas Tank Siphon [Re: Pynzo] #1811704
04/25/15 05:14 PM
04/25/15 05:14 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
up beer
