Air bleeds & jets.
#1809901
04/23/15 01:32 AM
04/23/15 01:32 AM
Posts: 12,591 Great Neck,LI,new york
hemi-itis
This may have been asked in the past,,,,,,,,but,why is it OK to drill air bleeds but a no-no on the jets.Having to change 8 at a time,being able to drill older smaller ones would make life good.
Re: Air bleeds & jets.
[Re: hemi-itis]
#1809917
04/23/15 02:13 AM
04/23/15 02:13 AM
Posts: 304 Florida
Mark Whitener
The problem with drilling jets is you may make the hole bigger but actually reduce the flow. If you look at the actual hole size of Holley jets you will find two size jets next to each other with the same size, but the length of the hole and whether it's chamfered or not will change the flow. Air isn't affected as much, although with the main air bleeds I usually won't drill, idle and intermediate air bleeds take a rather larger jump in size to effect a change so drilling isn't as much of an issue.
Mark Whitener [url=www.racingfuelsystems.com[/url]
[Re: hemi-itis]
#1810087
04/23/15 12:45 PM
04/23/15 12:45 PM
Thumperdart
State of confusion
Never have or will drill jets but almost always drill my own bleeds and of course set screws.
[Re: hemi-itis]
#1810128
04/23/15 01:38 PM
04/23/15 01:38 PM
Posts: 715 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
How about the margin of error is much greater when you are dealing with 12 parts of air vs 1 part of fuel.
Joe
Without Data, you’re just another guy with an opinion.
[Re: sr4440]
#1811322
04/25/15 01:16 AM
04/25/15 01:16 AM
hemi-itis
I use my drill indexed bits and measure the hole.Now I can increase the drill bit size to allow more fuel.If all 8 jets are drilled with the same bit,the orifices are the same,as would be another 8 jets to to a different orifice size.
Does this thought porocess make sence???
