what size exhaust pipes?
#181141
01/01/09 11:50 PM
01/01/09 11:50 PM
Posts: 649 Davis, California, USA
MrBelvedere2
I would like to do the exhaust on my 56 plymouth, right now it has a kind of patched together dual exhaust exiting out of the side with GM turbo mufflers on it that the Previous Owner installed. I want to put full dual exhaust out of the back with Dynomax Ultra Flow mufflers. My question is what diameter should i run? right now i measured the pipe coming out of the side it is 2-1/4. It is a stock 361 with a 2 barrel and exhaust manifolds but i plan on changing it over to a 4bbl soon. Should i go with 2-1/4 or 2-1/2?
1965 Plymouth Belvedere II hardtop
Re: what size exhaust pipes?
[Re: dave571]
#181145
01/02/09 10:38 AM
01/02/09 10:38 AM
Posts: 5,443 Indiana
YO7_A66
Indiana
Is there a hp rating or a chart that we could reference for the 2-1/4", 2-1/2", and 3" pipes,or is there just an understanding that if you have so much hp that you should run a certain size pipe?
I too am considering a larger exhaust pipe once I install my TTi's this Winter but I would like to understand some reason before I consider swapping out my 2-1/4" system. Thanks and Bump
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: YO7_A66]
#181146
01/02/09 11:47 AM
01/02/09 11:47 AM
Posts: 331 Bothell, Washington
71Swinger318
Bothell, Washington
I too agree on the 2.25" exhaust system. If you had a cam and headers, and you were aiming for performance, then 2.50" would do some justice. A 2.25" system will also keep the noise down. Another way to figure out what exhaust size to use, is pull the existing exhaust from the manifolds and measure the inner diameter of the collector flange.
Hope it helps, Bill
MoPar Or NoCar
1971 Dodge Dart Swinger
1978 Dodge Power Wagon Ex-Forest Service
1995 Jeep Grand Cherokee Limited 5.2/AWD
