accel pump stud snapped off flush in baseplate....
#181130
01/01/09 11:31 PM
01/01/09 11:31 PM
Posts: 1,586 Tampa, FL
tpabayflyer
Tampa, FL
I drilled a small hole in what was left of the stud and attempted to use an easy out. Big mistake. Easy out is now broken and it seems to be made of kyptonite as the drill won't even make a dent in it.........
I am thinking of using my die grinder and grinding it away if I can and then drill out the stud and re-tap or heli-coil if necessary. Anybody got any other ideas????? Somebody used thread sealer on the stud threads it seems... TBF
71 Challenger 528 Hemi project 09 Gr Cherokee 5.7 hemi in da house!!
Re: accel pump stud snapped off flush in baseplate....
[Re: NITROUSN]
#181132
01/01/09 11:45 PM
01/01/09 11:45 PM
im betting you'll destroy it trying to get it out. good luck!
[Re: tpabayflyer]
#181134
01/02/09 11:09 AM
01/02/09 11:09 AM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
That sucks. There are few things tougher than getting a broken off stud with an ez-out broken off in it. Sometimes, you can have some luck if you drill a very small hole just off to the side of the ex-out. It can release the stud's hold on it and let you dig the ez-out out of there without too much damage to the surrounding area. Good luck! I had to basically grind away the stud and surrounding area on a part once, have it welded to build it back up and then machined to get it flush again.
There was this guy in town many years ago, who had a business of removing things like this. He used a machine that uses electicity to zap little bits of the metal away until there is nothing left of the ez-out. It was like an electric drill bit without the bit.
Once this is past you, buy a quality set of left-hand cobalt drill bits.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: Evil Spirit]
#181137
01/02/09 12:14 PM
01/02/09 12:14 PM
tpabayflyer
Tampa, FL
Yeah... stock baseplate from a holley 3310 carb.. I just put my pro-form main body on and needed a larger accel pump squirt so I bought the 50cc pump kit. It uses a slightly different stud to mount the pump rocker arm so of course the original one was lock-tited in and it snapped off....... maybe I should cut my losses and just get a new baseplate, even the billet ones are not too bad pricewise.....
I am going to go out and see if i can work some magic with my small dremel die grinder..... If I mess it up I'll get just get a new baseplate..... TBF
[Re: tpabayflyer]
#181138
01/03/09 10:42 AM
01/03/09 10:42 AM
tpabayflyer
Tampa, FL
Well.. all of the above was pretty good advice..... I did spend a few bucks but I got it fixed. I used a tungsten carbide bit in my high speed dremel grinder and it took about an hour but I was able to grind out what was left of the easy out. I had to be careful not to press to hard and overheat the bit and possibly render it useless. I did use some of my head porting lube to keep the temps down. I did use a drill and install a heli-coil repair and now the accel pump works excellent.
In the future I will be much less inclined to use an easy out and go right into the heli-coil repair. It was quick and easy and took about 15 minutes total...... piece of cake.... TBF
[Re: Lee446]
#181139
01/03/09 10:59 AM
01/03/09 10:59 AM
jbc426
West Coast, USA
JBC, that is EDM, electrical discharge machining. Works good but used to be expensive. What is the baseplate off of?
Yah, yah! That's it!!!! EDM and it was big $
The real trick to 99% of broken bolt/stud removal are the left-hand drill bits. The natural rotation and heat from drilling them left-handed really does the trick. Most of the time the part will unthread out on the drill bit just before you get all the way through the piece..
[Re: jbc426]
#181140
01/03/09 11:07 AM
01/03/09 11:07 AM
Posts: 1,397 Toronto Ontario, Can
Glen440
when you have steel in aluminum you can mig the broken stud and then weld a nut to it. I do Ford crown vic heads all the time at work. Studs will be broken 1/4" in the head. The mig will not stick to the aluminum at all. Its done in the car as well.
I have to do my 03 Dakota some day, been putting it off as its the passenger side on a 4.7.
87 dakota 6.1 hemi
