Re: Dodge 413 motorhome head bolts
[Re: 413charger1968]
#1810879
04/24/15 01:04 PM
04/24/15 01:04 PM
Posts: 28,069 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
I assume the engine is destined for something with lots of hood clearance or an electric cooling fan?
#1811104
04/24/15 07:26 PM
04/24/15 07:26 PM
Posts: 43,282 Bend,OR USA
Cab_Burge
You do know those Mopar413industrial and motor home motors where never intended to rev much above 3500 RPM, correct? If not you may want to reconsider which heads to put money into Good luck either way
#1811303
04/25/15 12:39 AM
04/25/15 12:39 AM
Posts: 954 garnett kansas
rhad
garnett kansas
catapiller makes some really nice grade 8 bolts,i used to use them on olds diesels
my ladder of success is missing some rungs
#1811377
04/25/15 08:40 AM
04/25/15 08:40 AM
Posts: 7,664 IN
ahy
IN
Ok, i heard grade 8 are bad for head bolts because they dont stretch like a head bolt. And yeah im sticking it in a 68 charger 4 core rad and two fans lol. Anyone have any experience with porting these heads? Theyre 943 casting Some newer vehicles use "torque to yield" head bolts. They permanently stretch on installation by design. Muscle era MOPARs are not TTY and do not depend on permanent stretch. I don't think a bolt that is harder than original would hurt anything.
[Re: ahy]
#1811526
04/25/15 01:57 PM
04/25/15 01:57 PM
dogdays
"I heard" is usually followed by complete BS, as it is in this case. You now have reason to doubt anything that comes out of that "expert's" mouth.
Fact is, ANY bolt will stretch the same amount with the same load, until it starts to deform, usually by necking down. The reason to use a higher grade bolt is so you can tighten it tighter, providing more clamping force.
If, as I suspect, the head bolts that originally were in the 413 were Grade 8, then ANY grade 8 bolt will substitute perfectly well. And I really don't see why they need replacing in the first place. I've been reusing head bolts and every other kind of bolt for 40+ years, on stock type rebuilds. Actually I have only built one engine on which I replaced head bolts.
Your low compression industrial 413 isn't a high performance engine and I'd reuse head bolts without thinking twice.
As I said above, a Grade 8 bolt will work on any application in your engine EXCEPT for rod bolts, which are a specialized shape anyway.
R.
