Turn Signals #1806478
04/18/15 09:02 PM
04/18/15 09:02 PM
South Carolina
carhunter Offline OP
South Carolina
trouble with turn signals when I put the left one on it blinks until I put the lights on then the light gets real bright and stops blinking but the back is blinking so is the light on dash
the other side doesn't blink at all if I put the lights on this side just gets dim but the other side real bright any help would be great I have no ideal new turn signal and ignition switch.
Re: Turn Signals [Re: carhunter] #1806497
04/18/15 09:37 PM
04/18/15 09:37 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Make sure every body bulb socket on that circuit has a good ground. Use an ohm meter. SB .2 or less. Also, make sure the dash circuit board has a good ground.
Re: Turn Signals [Re: Lefty] #1806787
04/19/15 11:10 AM
04/19/15 11:10 AM
South Carolina
South Carolina
Thanks Lefty I changed 2 bulbs and they seem to work fine before the other bulbs would light but apparently they must of been bad thanks again.
