Kick Down Question A body #1806381
04/18/15 05:43 PM
04/18/15 05:43 PM
Streetsboro,Ohio
70dart318 Offline OP
Streetsboro,Ohio
I have a 1970 Dart with a 360 engine and a 904 trany. The kick down doesn't seem to be working. I also have a 1972 Duster with a 318 and a 904 trany. I looked at the likage n both cars and they are different. My question is they are both A-bodys with 904 's are should they be the same on both cars ? Thank You for any help
Re: Kick Down Question A body [Re: 70dart318] #1806386
04/18/15 05:55 PM
04/18/15 05:55 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
They should be the same, might see a slight difference in the shape of the upper link due to 2bbl vs 4bbl geometry, assuming one is a 2bbl and the other a 4bbl.
A bodies use what i call a three piece kickdown.
http://www.moparts.org/Tech/Archive/auto/35.html
Don't be the exception.
Re: Kick Down Question A body [Re: 70dart318] #1806564
04/18/15 11:28 PM
04/18/15 11:28 PM
Streetsboro,Ohio
Streetsboro,Ohio
Thanks, the adjustment must be off then.
