Alignment Hell - Please Help
#1805458
04/17/15 08:59 AM
04/17/15 08:59 AM
Posts: 1,526 North Carolina
cjskotni
North Carolina
Guys, I have been struggling with getting a decent alignment done on my Charger for the past two years! I have a local shop do it here and they had gotten it pretty close but since then I swapped the steering box to a FF stage III which threw it off a bit but I just drove it. I have since added FF 1.06 T-bars and had to disassemble the front suspension to get the Bilstien shocks installed so I wiped out whatever alignment was there... I took the car in yesterday to the same shop and gave them specs that Matt @ FF gave me. They worked on it for a good chunk of yesterday and got it as "close" as they could. It seems to drive fine/straight at low speeds <45mph but, on the highway it seems "darty" and seems to pull pretty hard to left...almost where you have to run with the wheel turned 10* to the right to stay straight! Here are the specs that they gave me. Do these look right? What would cause the hard pull to the left at high speed? I called the shop and they mentioned it could be radial pull but I call BS on that as it didn't do that before I did this work two weeks ago. Does anything stand out in these specs as "wrong"? I am not an alignment guy...I know the basics but I know that all the variables (camber/castor/toe/etc.) affect each other greatly. Do I need a new shop? What should I do to get this mess fixed?? I really want this car's suspension done for the spring and I'm tired of paying the "specialty price" for multiple alignments. Thanks!
Re: Alignment Hell - Please Help
[Re: BigBlockMopar]
#1805517
04/17/15 11:53 AM
04/17/15 11:53 AM
cjskotni
North Carolina
The difference in left and right SAI (Steering axis inclination) looks pretty high.
Are all the bushings still good? Has the car been in an accident at one time? Are you sure you have 2 exact same front wheels on the car?
Bushings are all good. They are all PST Polygraphite bushings and Energy Suspension k-frame mount bushings. I don't think this is the issue as I didn't have the problem before the most recent alignment. I don't know if the car has ever been in an accident but I don't think so. I have owned it for 11 years so not since then. Yes, both wheels are the same. What would cause a wierd SAI? I did have to pull the caliper/rotor/hub on the driver side to replace the lower BJ dust boot. However, if this was a stuck caliper, I would think the wheel would turn left when you let it go. This is where the wheel will pull straight but the car will go left unless you turn the wheel and hold it right.
[Re: cjskotni]
#1805729
04/17/15 05:19 PM
04/17/15 05:19 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Shim the steering box per the manual to get the SIA in from what I remember.... or slot the holes for the idler...Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: cjskotni]
#1805807
04/17/15 07:44 PM
04/17/15 07:44 PM
Posts: 6,516 Santa Cruz, California
Lefty
on the highway it seems "darty" Classic not enough caster problem. Mopar suspensions confuse alignment techs unless they are old dinosaurs or Mopar lovers. Find a different shop or you'll never get it right. Call around till you find one who's done old Mopars and understands the procedure in the FSM.
[Re: Kern Dog]
#1805964
04/17/15 11:43 PM
04/17/15 11:43 PM
cjskotni
North Carolina
I agree that you may need a different shop. On all classic Mopars, I like to run the following: 1/2 degree NEG Camber. 3-5 degrees POS Caster. 1/8" toe in. So if we can't hit those numbers what is the most important one to try and hit? I got the caster but apparently I lost the camber and toe...
[Re: cjskotni]
#1805969
04/17/15 11:46 PM
04/17/15 11:46 PM
Posts: 96,666 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
https://search.yahoo.com/search;_ylt=AnSvG3B18vJUzX_.G1XDyR6bvZx4?fr=yfp-t-901-s&toggle=1&fp=1&cop=mss&ei=UTF-8&p=front%20end%20alignment%20inchs%20to%20degrees%20conversion click here; convert
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: BergmanAutoCraft]
#1806157
04/18/15 11:16 AM
04/18/15 11:16 AM
cjskotni
North Carolina
Something is definetely wrong. You must have negative camber. Do you have offset upper arm bushings that were not installed correctly? The SAI is built into the spindle. Do you have the same spindles left and right? One may be bent. If the shop is using these specs and can't figure out what's going on, it's time for someone more competent. Ok guys, update here! I took the car to a Firestone here in town. When I spoke to the service manager there a few weeks back I mentioned the car and he seemed to know a thing or two about Mopars. He even claims to have owned a 71 Charger with a 440-6 that he sold back in the 80's...anyways I digress... When I pulled in this morning I popped the hood and he had me turn the wheel while he looked and low and behold the steering box is LOOSE! The sucker was moving probably 3/8" or so when I turned the wheel. No wonder the car is all over the road! What makes me really steamed about this is that this other shop supposedly spent all day working on this, charged me over $100, and let the car go out the door with a loose box. Anyways, I will pray that was my only problem and this car can get aligned properly now. I feel a bit embarrassed as I put the box in last summer and I never caught that. The again it's hard to catch that when you work on them by yourself without a helper. Oh well, I will keep you guys posted! Thanks for all the suggestions so far!
[Re: cjskotni]
#1806623
04/19/15 12:47 AM
04/19/15 12:47 AM
Posts: 797 WA
pro451bee
WA
By looking at the uneven SIA , I would suspect either the wheels were not locked , brake pedal applied , while doing the castor sweep and or the alignment heads slipped .Probably both , also the fact that the thrust angle is very important and not indicated on the print out is worrisome for me.The SAI for these cars is right about 7 deg for both sides .
