Is this a saginaw power steering pump? #1805432
04/17/15 04:16 AM
04/17/15 04:16 AM
Tacoma, Washington USA
Adam71Charger Offline OP
Im guessing this is a late model saginaw? Not familiar with federal pumps or what they look like
Re: Is this a saginaw power steering pump? [Re: Adam71Charger] #1805461
04/17/15 09:32 AM
04/17/15 09:32 AM
White Plains, NY
VCODE Offline
VCODE  Offline
White Plains, NY
You are correct
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
Re: Is this a saginaw power steering pump? [Re: Adam71Charger] #1805531
04/17/15 12:19 PM
04/17/15 12:19 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Yes, later style. Don't know when they started using those square cans. Guts are the same as the oval cans.
Re: Is this a saginaw power steering pump? [Re: Adam71Charger] #1805538
04/17/15 12:30 PM
04/17/15 12:30 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
When did they go to the press-on pulleys? I've got two of that style. I need one with a bolt on pulley.(keyed shaft) My 73 Challenger has the bolt on design. A 76 Newport I parted out had the press-on pulley.
Re: Is this a saginaw power steering pump? [Re: burdar] #1805643
04/17/15 02:55 PM
04/17/15 02:55 PM
Are you looking for original? 440 source has them remanufactured
http://store.440source.com/Power-Steering-Pump-Saginaw-w_keyed-shaft/productinfo/138-1007/
Re: Is this a saginaw power steering pump? [Re: Adam71Charger] #1805684
04/17/15 03:53 PM
04/17/15 03:53 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I was hoping to find a used one that I could put seals in myself. Local parts stores sell the pumps too. I assume both early and late style Saginaw reservoirs will mount to the pumps?
