thrust bearing fail #1805462
04/17/15 09:35 AM
04/17/15 09:35 AM
pa
572charger Offline OP
pa
anybody know why a 727 would tear up the back of the thrust bearing!!??? don't think the coverter is balloning ??
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: thrust bearing fail [Re: 572charger] #1805467
04/17/15 09:47 AM
04/17/15 09:47 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Just the back.. the conv is balloning and pushing forward on
the crank
wave
Re: thrust bearing fail [Re: 572charger] #1805513
04/17/15 11:48 AM
04/17/15 11:48 AM
Amarillo, Texas
BBR Offline
BBR  Offline
Amarillo, Texas
Line pressure possibly too high pushing the converter forward.
Drag Week 2011 - 77th place - DD
Drag Week 2012 - 2nd place SRBB N/A
Drag Week 2014 - Kapooya
RMRW 2018
RMRW 2020
Re: thrust bearing fail [Re: 572charger] #1805654
04/17/15 03:08 PM
04/17/15 03:08 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Most of these boil down to the pilot on the converter being bigger than the crank register.
Some more info would help. How much engine, what converter and what crank.
Kevin
Re: thrust bearing fail [Re: 572charger] #1805862
04/17/15 09:21 PM
04/17/15 09:21 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Jim, was a cam button used? A cam, walking out the block could pull the crank with it.
Re: thrust bearing fail [Re: 572charger] #1805912
04/17/15 10:25 PM
04/17/15 10:25 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
When I got my short block (Mopar Mega block, 4.5 Mopar crank from Indy) it only had 18 passes on it since freshened. I tore it down anyway and found the thrust torn up. Crank even showed a little heat. After talking to the previous owner he said he had a converter issue. I polished the crank and put it back in. It had the tightest crank end play I've ever measured, .003". It's been in the car for 200 passes. Just pulled the pan to check the bearings. Thrust looks like it came out of the box. My bet is converter.
Doug
Re: thrust bearing fail [Re: dvw] #1806361
04/18/15 05:04 PM
04/18/15 05:04 PM
Indiana
Cuda_Mike Offline
Cuda_Mike  Offline
Indiana
Who's converter?
Re: thrust bearing fail [Re: 572charger] #1806489
04/18/15 09:23 PM
04/18/15 09:23 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: thrust bearing fail [Re: 572charger] #1806796
04/19/15 11:22 AM
04/19/15 11:22 AM
pa
pa
its a ati convertor i have never had this problem before seemed to do it in one pass at the track on motor no no2 ?? same convertor and combo for 7 years i fresend the trans and motor 1 1/2 years ago rick it ahs a geardrive on it witha cam button all looked good there, i will send the covertor back ive had it for 10 yrs its a ATI blown fuel convertor and i will take the trans apart again to ck it thanks for all the in put
Re: thrust bearing fail [Re: 572charger] #1806810
04/19/15 11:55 AM
04/19/15 11:55 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Being that its a older conv and has many cycles on it, its possible
that the walls of the conv are getting weaker from flexing and is
actually starting to flex more... just a guess
EDIT
Didnt you use spray on that engine in the past.. if you did you
might have stretched the front wall and it has less distance to
move when it heats up
wave
Re: thrust bearing fail [Re: 572charger] #1807270
04/19/15 10:14 PM
04/19/15 10:14 PM
pa
pa
its a 606 cuin hemi calles crank and a ati convertor like i said before its all been together since 2007 , never a problem ive ssen turbo 400s ruin crank thrust bearings from the covertor charge hole size on the pump puts pressure on the convertor never heard of this on a 727 anybody else ??
Re: thrust bearing fail [Re: 572charger] #1807299
04/19/15 10:44 PM
04/19/15 10:44 PM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
I've seen it on a Hemi my builder did. His customer swapped the 440 in his 70 RR for the Hemi and used the trans and converter that was in the car. It wiped out the thrust on the Hemi in short order. The 440 thrust was OK.
The Hemi was built with the stock crank and just basically warmed up a little.
According to my trans shop you can run a Hemi core converter behind a wedge but you can't run a wedge converter core behind a Hemi. He said the register sizes are different. Hemi is smaller.
I have never measured to confirm this.
In any case a new converter and thrust bearing in the Hemi and all is well.
Kevin
Re: thrust bearing fail [Re: 572charger] #1807307
04/19/15 10:59 PM
04/19/15 10:59 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I've seen 3 where the thrust was wiped out on the rear.. all
3 were from the conv expanding... and I have heard of more
but I only seen the 3
EDIT
All 3 I seen were 727
wave
Re: thrust bearing fail [Re: 572charger] #1807536
04/20/15 09:19 AM
04/20/15 09:19 AM
pa
pa
gonna send the convertor back to ATI this week ill ck it in the back of the crank 1st, im gonna pull the trans out and check the end play and pull the pump out of it take a peek before putting it behind the new bullet , thanks for all replies , gonna call john at CRT also pick his brain !!! since all the trans parts are from him !!!!
Re: thrust bearing fail [Re: 572charger] #1807607
04/20/15 11:31 AM
04/20/15 11:31 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I was thinking about this last night... when you get a new
conv you might want to measure the thickness of the conv so
you have a reference later on... granted I have never done
it but maybe we all should
wave
Re: thrust bearing fail [Re: 572charger] #1807758
04/20/15 02:48 PM
04/20/15 02:48 PM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
If you can't seem to find anything wrong and certain the converter is not ballooning, add oil groves to that main. I had the same issue of wiping the thrust and couldn't find any evidence of the converter and was advised to add groves for extra oiling from my transmission builder who builds/races sprint cars. Have not had a problem since.
Re: thrust bearing fail [Re: 572charger] #1807961
04/20/15 06:30 PM
04/20/15 06:30 PM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
When you mated the trans to the motor did you check the end play of the converter between the flex plate and the aft most position of the vert before you bolted it to the flexplate? I have read that 0.125 gap is good. My latest build has about 0.100.
Re: thrust bearing fail [Re: TheOtherDodge] #1807979
04/20/15 06:50 PM
04/20/15 06:50 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
can you explain more on grooving.
Re: thrust bearing fail [Re: 572charger] #1808003
04/20/15 07:40 PM
04/20/15 07:40 PM
Houston, Texas
Houston, Texas
I didn't actually to the work to the bearing, but my understanding is that he added an extra grove to the thrust side of the bearing face to allow for better oiling. From what the tranny builder said, Fords are bad about wiping out the thrust due to poor oiling.
Re: thrust bearing fail [Re: 572charger] #1808292
04/21/15 01:27 AM
04/21/15 01:27 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
An automatic trans is ALWAYS trying to push the converter out the front, when the line pressure gets up, that's just a fact. Now, if you are pushing more fluid in the converter than it can exhaust, it will burn the thrust out of the motor. So what can cause that? If the converter has a sprag, it could be going out. Otherwise something in the trans is not allowing the converter to exhaust fluid properly.
Guys talk about "ballooning" all the time. You would need virtually zero snout clearance and an incredible amount of core expansion for that to actually hurt a thrust. Its normally always a fluid issue
Monte
