Do I need a breather setup...tunnel ram build.... #1804873
04/16/15 12:23 PM
04/16/15 12:23 PM
West Virginia
N
NewbombTurkk Offline OP
N
West Virginia
Ok...I had my tunnel ram drilled/tapped in the rear for power brakes/timing/modulator valve...but I didn't account for the PCV as I was going to tie into the brake booster line. Well, I read this shouldn't be done, so now I just have breathers on each valve cover....
Are there any drawbacks to this other than maybe some mist on my covers or more frequent oil changes? My engine is a worn out 402 in a 72 El Camino...I am going to post my results in the near future about adding a t-ram to a stock motor.....
1969 Buick Sportwagon 455 Stage 1 Ram Air SOLD
Nationwise Auto Parts Alumni 1982-1984
Now 1972 El Camino, original 402
Re: Do I need a breather setup...tunnel ram build.... [Re: NewbombTurkk] #1804896
04/16/15 01:02 PM
04/16/15 01:02 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
this is the "wiw" section. so, i'm guessing your set-up is worth maybe 40 bucks? shruggy
