Bypass Hose #1804509
04/15/15 11:01 PM
04/15/15 11:01 PM
Mid TN
2BblHarold Offline OP
Mid TN
I reused a water pump bypass hose on my 318, you know the short molded one, and I knew the fitting on the new Eddy manifold was wider than stock. The hose really seemed to stretch on install (I used Vaseline though). Sure enough, as soon as the stat cracked open, I've got a mess from the weakened, ruptured hose. Is there a part # solution to this, something a bit wider? This was probably a Gates.
Re: Bypass Hose [Re: 2BblHarold] #1804538
04/15/15 11:28 PM
04/15/15 11:28 PM
wider which way? any possibility of a pic? there's a Gates 20963 but that is likely the regular dimention one. has 1" ID for the 3/4 NPT nipple & does not appear to be longer or have a different bend than the normal ~90 deg ones. here's a BTT for ya. EDIT would adding a hardware store close nipple/45 deg female fitting solve this?
Re: Bypass Hose [Re: RapidRobert] #1804552
04/15/15 11:43 PM
04/15/15 11:43 PM
Mid TN
Mid TN
Wider: The fitting supplied on the eddy is wider than the stock mopar. I don't think an angled fitting would fix the problem, as the shape of the hose is fine. I might could use a stopdown adapter allowing me to reuse the mopar fitting. But it would seem to me that plenty of folks are not having to do that.
Re: Bypass Hose [Re: 2BblHarold] #1804574
04/15/15 11:58 PM
04/15/15 11:58 PM
md
mopars4ever Offline
mopars4ever  Offline
md
what year 318? earlier years had a smaller bypass hose IIRC
Re: Bypass Hose [Re: mopars4ever] #1804644
04/16/15 01:01 AM
04/16/15 01:01 AM
Mid TN
Mid TN
68. Smaller, eh? Maybe I'd have luck if I looked for a unit for a 360.
Re: Bypass Hose [Re: 2BblHarold] #1804666
04/16/15 01:24 AM
04/16/15 01:24 AM
md
mopars4ever Offline
mopars4ever  Offline
md
The later small blocks use a larger bypass hose. I know my 73 did.
Re: Bypass Hose [Re: mopars4ever] #1804747
04/16/15 04:38 AM
04/16/15 04:38 AM
Harold Are you saying the nipple in the intake is larger than the 1" OD (3/4" NPT) nipple that Ma uses? We need a pic?
Re: Bypass Hose [Re: RapidRobert] #1804763
04/16/15 06:43 AM
04/16/15 06:43 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
evidently have an early water pump with the smaller bypass fitting and the intake is made to utilize the later large bypass hose. Best fix is to get the later water pump.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: Bypass Hose [Re: MoparforLife] #1804860
04/16/15 12:04 PM
04/16/15 12:04 PM
Mid TN
Mid TN
RRobert: Yes, that's what I'm saying. I just didn't want to write "nipple".
MfL: Makes perfect sense!
