Re: "Best Gasket" rope rear main seal leaks bad. HELP!
[Re: WarEagle1]
#1803936
04/15/15 02:32 AM
04/15/15 02:32 AM
RapidRobert
As you know it has to come apart again (unfortunately). not from the PCV (lack of)
[Re: WarEagle1]
#1804142
04/15/15 01:38 PM
04/15/15 01:38 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Billet rear main seal retainers have been known to be machined off center. Which means lot's of friction on one side, an oil leak on the other.
[Re: WarEagle1]
#1804185
04/15/15 02:29 PM
04/15/15 02:29 PM
Posts: 75,088 A Banana Republic near you.
JohnRR
My MP block was manufactured in Nov. '13 and I'm using the billet seal retainer that came with it. Has the offset problem showed up in stuff this new? Did anyone find a problem with the MP part in particular? Is it a World block ? Did you install the retainer before putting in the crank to check the alignment? The tip off that you were faced with an issue would have been the crank being really hard to turn if installed the seal correctly. I don't know how it would happen but the seal side of the block could have been machined wrong , Dan Costello had that issue with a Hemi he did for someone , finally tracked that leack down to the block being machined wrong .
[Re: WarEagle1]
#1804422
04/15/15 09:01 PM
04/15/15 09:01 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
I think it would be a World block. P/N was P5153862AB. Was manufactured just over a year ago. Is that the right period for World blocks? The retainer was installed in the block, as received. The crank was hard to turn after adding the seal, but I assumed that was standard for a rope seal. As for the retainer, should I remove it and compare the geometry to a stock version? Your awfully fixated on the rear seal being the source of the leak..... why don't you find out exactly where the leak is coming from and go from there?
