Removing trunk tension rods E Body #1801624
04/12/15 12:35 PM
04/12/15 12:35 PM
Dr Dave Offline OP
Dr Dave  Offline OP
Any tips to removing these rods without losing a finger? I need to remove a hinge and repair a oval socket to fix a nasty rattle. Anyone else have this issue? Drivers side, 71 Cuda.
Re: Removing trunk tension rods E Body [Re: Dr Dave] #1801921
04/12/15 08:54 PM
04/12/15 08:54 PM
Dr Dave Offline OP
Dr Dave  Offline OP
No tips??
Re: Removing trunk tension rods E Body [Re: Dr Dave] #1801952
04/12/15 09:30 PM
04/12/15 09:30 PM
michigan
440whiteboy Offline
440whiteboy  Offline
michigan
I removed the rods before by going inside the trunk with a light to remove them - they should have less tension. You could mark the holes on each side or take pictures - to get it back the same way.
They only see Stars...
when hit by a Mopar!
Re: Removing trunk tension rods E Body [Re: 440whiteboy] #1802124
04/13/15 12:27 AM
04/13/15 12:27 AM
Dr Dave Offline OP
Dr Dave  Offline OP
That's a great idea, thanks! By the way, '71 Cuda has only 1 rod (saw that there was some question on another thread)
