Page 4 of 7 1 2 3 4 5 6 7
Re: The turbo Cuda build has begun [Re: Shaker223] #180223
02/07/09 09:42 PM
02/07/09 09:42 PM
Dirty Dena, Maryland
dodge turbo Offline
dodge turbo  Offline
Looking good....cant wait to see it run,,,,where do you normally race at??
78 Adventurer 150small block turbo'd 360w/Borg S475....smoke'em
Re: The turbo Cuda build has begun [Re: dodge turbo] #180224
02/07/09 09:53 PM
02/07/09 09:53 PM
Jarrettsville, MD
cudaman1967 Offline OP
Jarrettsville, MD
Cecil and Capitol
Cudaman1967 1967 Barracuda Turbo Outlaw 8.50
Re: The turbo Cuda build has begun [Re: cudaman1967] #180225
07/26/09 10:34 PM
07/26/09 10:34 PM
Jarrettsville, MD
Jarrettsville, MD
Well after 7 months I finally the car almost done. Broke the motor in this weekend. Then hooked up the turbo and man does this thing sound bad to the bone! Cant wait to drive it. Still have some wiring to complete with the Zeitronix and Labonte Water/Meth amoung a few other items. Should be on the road in the next 2-3 weeks I hope...
Re: The turbo Cuda build has begun [Re: cudaman1967] #180226
07/26/09 11:11 PM
07/26/09 11:11 PM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
Looks great! Thanks for the progress and pics!
Re: The turbo Cuda build has begun [Re: TheOtherDodge] #180227
07/26/09 11:32 PM
07/26/09 11:32 PM
The Wet Coast, Canada
megajoltman Offline
megajoltman  Offline
SWEET!
1969 Dart 383/727/D60
CTD Ram 4x4 Mega Cab
Procharged 350Z
Re: The turbo Cuda build has begun [Re: cudaman1967] #180228
07/27/09 03:10 PM
07/27/09 03:10 PM
SE Nunya
Bubba Offline
Bubba  Offline
SE Nunya
I love it.
Re: The turbo Cuda build has begun [Re: Bubba] #180229
07/27/09 08:12 PM
07/27/09 08:12 PM
Baltimore,MD
lowbudget Offline
mopar addict
lowbudget  Offline
mopar addict
Baltimore,MD
Jesus, that thing is badd..hope to see ya around this year
Re: The turbo Cuda build has begun [Re: lowbudget] #180230
07/27/09 09:12 PM
07/27/09 09:12 PM
Jarrettsville, MD
Jarrettsville, MD
Thanks Guys! Been alot of hard work. Been planning for 2 years. Got tired of bracket racing after 15 yrs and wanted to try something different.
Re: The turbo Cuda build has begun [Re: cudaman1967] #180231
07/28/09 12:11 PM
07/28/09 12:11 PM
AB
E
Efidart Offline
Efidart  Offline
E
AB
X2 on the BBQ of the wideband. Under boost you will start to get overheating errors, should be around 18" from the turbo.
TT Predator headed 572 7 Second Street Car.
Fastest Mopar Drag Week 2015
Fastest Mopar & Dodge Drag Week 2017
Pro Street Power Adder Champion Drag Week 2017
Re: The turbo Cuda build has begun [Re: Efidart] #180232
07/28/09 12:42 PM
07/28/09 12:42 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
More pic's please
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: The turbo Cuda build has begun [Re: BloFish] #180233
07/28/09 04:32 PM
07/28/09 04:32 PM
Arizona
Chris'sBarracuda Offline
Arizona
Great Job Mike..
Keep us posted..
Chris..
Re: The turbo Cuda build has begun [Re: BloFish] #180234
07/28/09 06:17 PM
07/28/09 06:17 PM
Mcallen, TX
SB449VALIANT Offline
Mcallen, TX
More pic's please
Update: The turbo Cuda build [Re: SB449VALIANT] #180235
09/14/09 09:28 PM
09/14/09 09:28 PM
Jarrettsville, MD
Jarrettsville, MD
Well I am 90 percent there. Working the bugs out. It is unreal!!! Faster than my alcohol 9.40 motor on the pump and water/meth with only 7lb of boost.
Need to get painted once the bugs are all worked out. I have put almost 100 miles on it. Rides smooth! Need to put the mesh grill in and do the body work.
I am thinking DP50 satin black. Thoughts?
Re: Update: The turbo Cuda build [Re: cudaman1967] #180236
09/14/09 09:28 PM
09/14/09 09:28 PM
Jarrettsville, MD
Jarrettsville, MD
another
Re: Update: The turbo Cuda build [Re: cudaman1967] #180237
09/14/09 09:31 PM
09/14/09 09:31 PM
Jarrettsville, MD
Jarrettsville, MD
special thanks to Zeitronix! I couldnt of tuned this car with out there on board computer!
Thanks Marc!
www.zeitronix.com
Re: Update: The turbo Cuda build [Re: cudaman1967] #180238
09/14/09 11:42 PM
09/14/09 11:42 PM
Grande Prairie, Alberta, Can.
CW25 Offline
CW25  Offline
Awesome when is the track date for some inital numbers.
11.67@118 1.88 60' with only 7-8 lbs of boost. Turbocharged, megasquirted, 407 BB, 440 source heads, roller cam, 9:1 comp. http://s292.photobucket.com/albums/mm14/beansgracie
Re: Update: The turbo Cuda build [Re: cudaman1967] #180239
09/15/09 04:43 AM
09/15/09 04:43 AM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
keepup the good work.thanks for posting the update!
Re: Update: The turbo Cuda build [Re: cudaman1967] #180240
09/15/09 06:38 AM
09/15/09 06:38 AM
St. Clair Shores, Michigan
bigsbigelow Offline
bigsbigelow  Offline
YES!!! Satin black would look killer on your car. I also think it looks pretty darn cool the way it is.
Ryan "Bigs" '73 Duster (BLKDUST) - Black, 100% factory sheet metal, flat hood, 346 cid, J Heads, and a bench seat. http://s268.photobucket.com/albums/jj1/bigsbigelow/ Best to date: 12.40 @ 109 mph
Re: Update: The turbo Cuda build [Re: cudaman1967] #180241
09/15/09 12:34 PM
09/15/09 12:34 PM
land of 10,000______'s
BDS871Cuda Offline
BDS871Cuda  Offline
All that work and you want to paint it one color
off of flat black (yes, satin black is to close to
flat black). Toss on some House of Kolors Chrome
Black, or give it a Candy Tangerine look. Change
it up a bit like a Candy Pearl Teal.
Anything but (ratrod) (flat) satin black.
But then again it's your choice in the end.
Awsome car!!!!!
Snap your neck, mega G-force launch, is all I want!
Re: Update: The turbo Cuda build [Re: BDS871Cuda] #180242
09/15/09 01:04 PM
09/15/09 01:04 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Awasome
