Rear thrust angle #1792711
03/31/15 06:46 PM
03/31/15 06:46 PM
Dr Dave Offline OP
Dr Dave  Offline OP
I was reading on the Hotchkis site about shims to correct midline alignment between the front and rear wheels ( thrust alignment) by shimming the rear leaf spring mount. They talk about using an alignment shop to measure and determine if there is a misalignment. How can we do this accurately at home? I think I may have this issue as my car (Cuda) does not want to launch straight under heavy acceleration. Thanks!
Re: Rear thrust angle [Re: Dr Dave] #1792712
03/31/15 06:52 PM
03/31/15 06:52 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
Tape it. Also check that all the bushings in the rear leaf shackles, etc., are good.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Rear thrust angle [Re: amxautox] #1792713
03/31/15 10:59 PM
03/31/15 10:59 PM
Long Island, NY USA
BergmanAutoCraft Offline
Long Island, NY USA
I invented those shims years ago. I keep them in stock on my site - Bergmanautocraft.com. Let me know with any questions.
Re: Rear thrust angle [Re: BergmanAutoCraft] #1792714
03/31/15 11:02 PM
03/31/15 11:02 PM
Long Island, NY USA
Long Island, NY USA
Dave - Best thing to do is to find one of the frame measurement holes that is symmetrical left to right. I do a cross measurement from the hole in the frame to the center bolt of the leaf spring. That will give you a good idea of what is going on in the rear. Usually, the pass side needs a shim or two. I make them in 1/8".
Re: Rear thrust angle [Re: BergmanAutoCraft] #1800423
04/10/15 05:31 PM
04/10/15 05:31 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Slick thumbs
The FSM should have the chassis drawings in the body section that shows the correct frame measurement hole locations.
Re: Rear thrust angle [Re: Dr Dave] #1800452
04/10/15 06:27 PM
04/10/15 06:27 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I would take it to an alignment shop, they can do it and its no headache!
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Rear thrust angle [Re: astjp2] #1800698
04/10/15 10:56 PM
04/10/15 10:56 PM
Long Island, NY USA
Long Island, NY USA
If you can find an alignment shop that not only can do a real alignment adjusting caster camber and toe, that's a feat in itself these days. To go the extra mile and be able to measure and correct thrust angle is not going to be easy with the current crop of "set the toe and let it go" mentality.
Re: Rear thrust angle [Re: Dr Dave] #1801097
04/11/15 03:44 PM
04/11/15 03:44 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Took me a while to find a good alignment shop, but I go to the one that does all the heavy duty trucks in town.
Don't be the exception.
