E-Body rear end swap options #1799909
04/09/15 11:53 PM
04/09/15 11:53 PM
Alaska
73rrak Offline OP
73rrak  Offline OP
Alaska
Does anybody have a link to the list of what rear ends will fit an E-Body ? I have a 72 Challenger and would like to find out if the Dakota or Durango will fit in it without narrowing it. Or what other options are available. I know I've seen a list but I just can't find it.
Re: E-Body rear end swap options [Re: 73rrak] #1803033
04/14/15 04:16 AM
04/14/15 04:16 AM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
they wont bolt in.
5549 post on old board
Re: E-Body rear end swap options [Re: 73rrak] #1805596
04/17/15 01:57 PM
04/17/15 01:57 PM
Alaska
73rrak Offline OP
73rrak  Offline OP
Alaska
Ok how about a disc brake rear end that's the right length that I can weld new spring perches on and bolt in. I would prefer to do some junkyard hunting instead of spending a bunch of money having a rear end narrowed.
Re: E-Body rear end swap options [Re: 73rrak] #1805841
04/17/15 08:43 PM
04/17/15 08:43 PM
dogdays Offline
dogdays  Offline
I think the solution is to use your own rear end and bolt on disk brakes from a Grand Cherokee, as the ends of the axles are the same.
Better yet, talk to Doctor Diff as he has a kit.
R.
