Tires on original 69 Magnums #1799198
04/09/15 09:49 AM
04/09/15 09:49 AM
NC
Sixt8Chrgr Offline OP
NC
What is the widest tire you can put on a 14" magnum in the rear? The magnums are the original wheels best I can tell.
Same question for the front?
I am thinking about either repainting the original wheels or either buying new wheels for the 69. In any case new tires will be bought.
Lawrence
Re: Tires on original 69 Magnums [Re: Sixt8Chrgr] #1799566
04/09/15 05:55 PM
04/09/15 05:55 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
I wouldn't go any wider then an 8 inch tire.
I think I recall reading somewhere,
that you should not exceed 3 inches wider than the rim width.
The magnums I have are 14X5.5 and 14X6 inch.
Original 14", not the chrome 15" after market ones.
Have you found a decent set of 14 inch tires?
I read every where that they are scarce and expensive.
Would love to find a couple sets.
I have a set of magnums as well as a set of 14" slots .
I have mechanical Aptitude.
I can screw up anything.
Re: Tires on original 69 Magnums [Re: bboogieart] #1799628
04/09/15 07:05 PM
04/09/15 07:05 PM
massachusetts U.S.A.
1969ronnie Offline
1969ronnie  Offline
hi, 225-70-14 or a little taller to fill the wheel well 225-75-14 if you can find them. ron
