69 a-body rear springs #1799225
04/09/15 10:41 AM
04/09/15 10:41 AM
Shelby, Ohio
2
2abodymcodes Offline OP
Shelby, Ohio
are these the correct rear leaf springs for my 69 cuda ? chrysler part number P4510268 and P4510269.
Re: 69 a-body rear springs [Re: 2abodymcodes] #1799237
04/09/15 10:58 AM
04/09/15 10:58 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Those are Mopar Performance springs.
http://www.jegs.com/i/Mopar-Performance/312/P4510269/10002/-1
JB Rhinehart, Realist
A-Body's RULE!
Re: 69 a-body rear springs [Re: Rhinodart] #1799242
04/09/15 11:00 AM
04/09/15 11:00 AM
Shelby, Ohio
2
Shelby, Ohio
i put those on my car 2 years ago. it sits up so high i cannot get my rear shocks on it. the car looks like it's stuck in the 70's. i thought it might settle after sitting but it has been sitting for 2 years now. i'm thinking they sold me the wrong ones.
Re: 69 a-body rear springs [Re: 2abodymcodes] #1799258
04/09/15 11:25 AM
04/09/15 11:25 AM
"sitting" you dont mean sitting as in not being driven do you? I would think they would need to occillatations/flexing produced from being driven to make em settle as opposed to just having weight on them. What about some lowering blocks? My 65 dart roller came with 003/003 SS springs & I needed shock extensions but the height was perfect & it rode very very nice. OP the P prefix denotes a MP performance part which would not be an OE spring if I am reading your question correctly
Re: 69 a-body rear springs [Re: RapidRobert] #1799300
04/09/15 12:32 PM
04/09/15 12:32 PM
Shelby, Ohio
2
Shelby, Ohio
yes i know they are mopar performance items. i am still assembling the car so i have not driven it. it sits up so high that i cannot install the rear shocks. i even tried jacking the rear shackles back with a porta power. the car looks like it has air shocks on that are pumped up all the way.
Re: 69 a-body rear springs [Re: 2abodymcodes] #1799336
04/09/15 12:54 PM
04/09/15 12:54 PM
that is surprising that they are that high but maybe mine were used/had settled (I bought it as a roller) and I ain't sure which of the 002/003's is the higher but mine had (2) 003's for a level ride but I did need a pair of those garden variety shock mt extensions that I happened to have laying around. Would some lowering blocks take care of you? I would want the rear shackles at a reasonably correct angle (lower end down & to the rear ~45 deg. EDIT 14's in top pic/15's below
Re: 69 a-body rear springs [Re: 2abodymcodes] #1799347
04/09/15 01:07 PM
04/09/15 01:07 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
You might have to get the springs reset if you want it to sit lower..
Re: 69 a-body rear springs [Re: OzHemi] #1799439
04/09/15 03:12 PM
04/09/15 03:12 PM
Shelby, Ohio
2
Shelby, Ohio
my shackels are pointed straight down. i tried forcing them back with a porta power but they will not stay. even with them being forced back to a 45 degree angle the rear of the car is still way too high. i can post a picture tonight.
Re: 69 a-body rear springs [Re: 2abodymcodes] #1799577
04/09/15 06:13 PM
04/09/15 06:13 PM
Actually with more thought I think you are fine on the shackle angle but you will need to alter something (else) to get the car lowered. I'm still thinking lowering blocks
Re: 69 a-body rear springs [Re: 2abodymcodes] #1799598
04/09/15 06:41 PM
04/09/15 06:41 PM
Illinois
StrkrDart69 Offline
StrkrDart69  Offline
Illinois
I have a 69 Dart. I bought my springs from Mancini. Many here on Moparts said the SS springs sat high, and they suggested using the heavy duty springs instead. That is what I used and I think my car sits perfect. I would post a pic but I have not figured out how to do that yet.
Re: 69 a-body rear springs [Re: StrkrDart69] #1799607
04/09/15 06:46 PM
04/09/15 06:46 PM
Illinois
StrkrDart69 Offline
StrkrDart69  Offline
Illinois
Hey pic worked!
Re: 69 a-body rear springs [Re: 2abodymcodes] #1799697
04/09/15 08:16 PM
04/09/15 08:16 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
what is your shackle length? if its too long it could force the car up. old 70's trick
Re: 69 a-body rear springs [Re: Rhinodart] #1799728
04/09/15 08:57 PM
04/09/15 08:57 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
I used B Body Dodge front spring hangers flipped upside down on Dad's 69 Dart. Moved the rear both back and up at the same time. up
On my 70 Satellite I used the Mancini B body hangers in the top hole and still had to add 1 1/2" lowering blocks to get it to sit right. The more tire your trying to use the worse it is... twocents
...FAFO...
Re: 69 a-body rear springs [Re: skicker] #1799791
04/09/15 10:12 PM
04/09/15 10:12 PM
Illinois
StrkrDart69 Offline
StrkrDart69  Offline
Illinois
Love that Dart
Re: 69 a-body rear springs [Re: StrkrDart69] #1799840
04/09/15 11:00 PM
04/09/15 11:00 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I know that s couple friends who used those springs and put a couple hundred pounds in the trunk while the car was sitting before it was drivable. work
A-Body's RULE!
Re: 69 a-body rear springs [Re: Rhinodart] #1799881
04/09/15 11:24 PM
04/09/15 11:24 PM
Shelby, Ohio
2
Shelby, Ohio
Not the best picture, but you get the idea. shackels are stock length.
Re: 69 a-body rear springs [Re: 2abodymcodes] #1799885
04/09/15 11:27 PM
04/09/15 11:27 PM
Shelby, Ohio
2
Shelby, Ohio
sorry, have no idea how to post a picture anymore
Re: 69 a-body rear springs [Re: 2abodymcodes] #1799886
04/09/15 11:28 PM
04/09/15 11:28 PM
Shelby, Ohio
2
Shelby, Ohio
it worked. rear shackel
Re: 69 a-body rear springs [Re: 2abodymcodes] #1799947
04/10/15 12:35 AM
04/10/15 12:35 AM
Illinois
StrkrDart69 Offline
StrkrDart69  Offline
Illinois
WOW that is high. shock
Re: 69 a-body rear springs [Re: StrkrDart69] #1799961
04/10/15 12:55 AM
04/10/15 12:55 AM
(1) put some 20's on there! (2) dearch the main leaf(s) (3) lowering blocks
