4 wheel drive problem '97 ram 1500??? #179853
12/31/08 05:11 PM
12/31/08 05:11 PM
Western Colorado
3
340Scamp Offline OP
340Scamp  Offline OP
Western Colorado
4 wheel drive works, then will pop out of gear. If I mess with the floor lever it will go back in at times. Is there a switch in the shift linkage that activates the vacuum module on the differential housing?
Re: 4 wheel drive problem '97 ram 1500??? [Re: 340Scamp] #179854
12/31/08 05:50 PM
12/31/08 05:50 PM
Crook County, ILL
Mastershake340 Offline
Crook County, ILL
Here is a thread from a guy having a similar problem:
https://board.moparts.org/ubbthreads/show...e=0#Post4865796
