Re: Big block A-body cooling
[Re: minivan]
#1798798
04/08/15 08:12 PM
04/08/15 08:12 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
I have read on this site about the water pump impeller being loose on the shaft.. Might want to take your water pump off and check it..
Ditch the flex fan as said above more than once and use a good stock fan with a good clutch fan... Good guesses. They involve both time and money that may not be needed if he gets a temp gun and finds out what the temperatures look like. If the impeller was loose then water would not flow. To check that all he has to do is remove the cap and see if coolant is flowing.
[Re: 71_Demon]
#1801555
04/12/15 10:20 AM
04/12/15 10:20 AM
Posts: 1,520 West Palm Beach, Florida
Copper Dart
Let's say the cooling system is ok.
What could be happening inside the engine that makes it such a high BTU water heater??? I'm just curious, I have seen in the past some engines just make a lot more heat than others and I've always thought that it has more to do with tuneing and the Cam setup ( when the obvious issues are addressed and taken care of like intake leaks and stuck stats, poor or missing shrouds etc. ) these things can answer a lot of questions and save the OP time and money.
Common sense, the least common of all the senses. Mom.
For fear of ridicule, society stifles creativity. Ricky Valdes
