Re: Steeringcolumn Broadcastsheet codes..
[Re: 71redcuda]
#1796255
04/04/15 03:46 PM
04/04/15 03:46 PM
Posts: 8,948 Harlan, Iowa
69CoronetRT
Harlan, Iowa
What does the difference between steering column codes on broadcast sheets like 215x97000 255x97000 255x970005 mean?
Depending on the application, the steering column code could indicate:
Colum automatic, Column manual, Console automatic, Floor shift, manual tilt/telescopic, with or without speed control or other things that could be related to or associated with options or applications of that particular column.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs. Over 2,000 thanks to you!
