Re: a body rear shocks
[Re: ragin sonny]
#1795881
04/04/15 10:58 AM
04/04/15 10:58 AM
Posts: 19,629 north of coder
moparx
looking through my monroe master catalog, the a-body rear shock has L-2 ends, which are 11/16 dia. with no metal sleeve. this is the standard shock plate diameter for the b & c bodies, as well as the i/2 & 3/4 ton trucks. the a-body lengths are 14.125 collapsed and 23.500 extended. the only thing i could find that had the L-2 ends top & bottom was the front shocks for 61-71 dodge 1/2 & 3/4 ton 2wd trucks with the beam axle, and the same shock was used on the rear of P-200 camper conversions 69-71. the number of this shock was a rancho LE10022. the lengths for this was 14.880 collapsed and 25.00 extended. also, this has been a discontinued number, as i could not find a superseded number, or current availability in a current monroe catalog. you may find an off road place that has a listing for these, but it looks like you are going to have to push out the upper bushings on something more currently available. hope this has been of some assistance.
