4 SPD CONSOLE TOP PLATE HELP
#17952
10/30/05 11:33 AM
10/30/05 11:33 AM
Posts: 396 Queens N.Y.
diesel1114
super street
super street
Queens N.Y.
CAN ANYONE OUT THER GIVE ME A MEASUREMENT OF THERE TOP PLATE OPENING FOR THE SHIFTER HANDLE , GOING TO ATTEMPT TO CONVERT AND AUTOMATIC 1 , IF YOU CAN PROVIDE SOME PICS EVEN A COMPARISON OF TEH 2 NEXT TO EACHOTHER ITS GREATLY APPRECITED THANKS JOHN
JOHN WS23L8GXXXXXX
Re: 4 SPD CONSOLE TOP PLATE HELP
[Re: diesel1114]
#17954
10/30/05 03:53 PM
10/30/05 03:53 PM
Posts: 3,719 Space Station #5
471Magnum
Space Station #5
Been there, done that. 6.75" from the back edge. 13" from the back edge to the front of the opening.
-Jim
I can fix it... my old man is a television repairman. He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
[Re: 65Frank]
#17957
10/31/05 11:45 AM
10/31/05 11:45 AM
471Magnum
Space Station #5
That’s pretty much it for the pictures. Takes a whole lot of grinding, and that is some HARD material. It’s not pot metal. Once I was done hacking, I took a thin piece of sheet metal and patched the rear of the hole. I JB Welded some sheet metal screws to act as studs for retaining the boot. Installed some reproduction wood grain. Trimmed out the front and read of the hole with pieces of door edge guard molding. Pretty convincing conversion, especially considering what decent 4-speed plates are going for these days ($400+).
-Jim
[Re: Clair]
#17960
10/31/05 04:49 PM
10/31/05 04:49 PM
Posts: 75,094 A Banana Republic near you.
JohnRR
Nice Job 71 I like the door edge trick what did you use for a boot ???
looks like the stock boot , and its still available , i got 2 nos ones a few years ago ...
[Re: 471Magnum]
#17963
10/31/05 09:23 PM
10/31/05 09:23 PM
JohnRR
Non-pistol grip boots are available... but not cheap.
The '70 boots are not available as far as I know.
what he said and i'm surprised they don't repop the 70 boot ...
[Re: JohnRR]
#17968
11/01/05 01:39 PM
11/01/05 01:39 PM
471Magnum
Space Station #5
Try that with a '68.
unfortunately you can't because the 68 doesn't have woodgrain insert
You probably could splice in the ribbed texture, but it would require a lot more talent than I had to draw upon for my hack job.
