MP dual springs for small block .557 cam #1792353
03/31/15 07:52 AM
03/31/15 07:52 AM
S.E. Minnesota
gtsdude Offline OP
gtsdude  Offline OP
S.E. Minnesota
Thinking of trying the small block MP .557/296 solid cam, calls for the MP 3614542 dual springs. The retainer for these springs is MP 4452033 and is listed for single and dual MP springs. My question is, are they the same retainers used as the stock replacements? My X heads are already machined for dual springs so if I could reuse my retainers and locks it would be a drop in.
Re: MP dual springs for small block .557 cam [Re: gtsdude] #1792354
03/31/15 12:31 PM
03/31/15 12:31 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
MP springs, except for the stock hydraulic stuff, are junk. The spring pressures will not be correct. Use a Comp or other manufacturers spring along with whatever retainer they recommend.
Re: MP dual springs for small block .557 cam [Re: Sixpak] #1792355
03/31/15 02:56 PM
03/31/15 02:56 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
^^^^ this ^^^^
I would definatly use another vendor for springs. I've actually had springs with different pressures from MP in the past. Howards Cams is a good source, good prices and VERY customer service friendly.
Re: MP dual springs for small block .557 cam [Re: cudadoug] #1792356
03/31/15 03:43 PM
03/31/15 03:43 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
^^^^^^^ this X3, MP seat pressure will be all over the map as evedenced by a set I have in a box sitting high on a shelf out of sight.
Re: MP dual springs for small block .557 cam [Re: dartman366] #1792357
04/01/15 03:32 AM
04/01/15 03:32 AM
S.E. Minnesota
gtsdude Offline OP
gtsdude  Offline OP
S.E. Minnesota
thanks
