Re: Hemi 6 wiring harness
[Re: MattW]
#1791428
03/29/15 10:26 PM
03/29/15 10:26 PM
Posts: 344 Burlington, Ontario Canada
Dave_S
Sure you can, but the Dealer cant get you the connectors. Unfortuneately they are not serviced. Your best bet is to get a harness from the wreckers. That's what I did.
Dave Stillie '73 Swinger 5.7 Hemi, 88mm turbo, powerglide, cal-tracs & 8 3/4 Mega-Squirt EFI [email]8.93@149 [/email]
[Re: Dave_S]
#1791429
03/29/15 11:45 PM
03/29/15 11:45 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
You can either cut them off an existing harness in the junk yards or, if you do some research, you can find the connectors on line. I was building custom 2 step harnesses for the Gen 3 hemi's for a while. I would buy the connectors, both male and female, for the hemi's. The yellow terminal locks had to be ordered separate. Not expensive at all.
[image][/image]
[Re: MattW]
#1791431
03/30/15 04:05 PM
03/30/15 04:05 PM
sgcuda
I found 7 coil connectors at work. PM me your address and I'll ship them to you. In the mean time, I will look around for an 8th one.
Kenny
[image][/image]
[Re: sgcuda]
#1791432
03/30/15 04:14 PM
03/30/15 04:14 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
Kenny
Wow thx
[Re: sgcuda]
#1791436
03/31/15 04:21 PM
03/31/15 04:21 PM
MattW
Ontario Canada
Here's a pic of the harnesses I was building to work with the N2MB wotbox.
What a N2MB wotbox?????
[Re: MattW]
#1791437
03/31/15 08:36 PM
03/31/15 08:36 PM
sgcuda
It's a 2 step launch control/rev limiter. The harnesses would go inline with factory harness for quick installation. For the manual trans guys, it would also stutter the ignition during shifts for wide open throttle shifting.
[image][/image]
[Re: sgcuda]
#1832485
05/22/15 09:52 PM
05/22/15 09:52 PM
MattW
Ontario Canada
Kenny Finally got to the states to pick these up. Once again Thank you Kenny Hopefully I can repay the favor. Matt
[Re: sgcuda]
#1832492
05/22/15 10:01 PM
05/22/15 10:01 PM
MattW
Ontario Canada
You're welcome, Matt. Glad you finally got them. Let me know if there is anything else I can help with.
Kenny Got another post about R5P7. LOL
