hemi blk to wedge motor mounts? #1791165
03/29/15 02:11 PM
03/29/15 02:11 PM
K
KOS Offline OP
KOS  Offline OP
K
Guys im running an indy maxx aluminum block that has hemi style motor mounting in a 68 b-body that has a BBwedge k-member.whos the best bet for a conversion mount for this arrangement?
Re: hemi blk to wedge motor mounts? [Re: KOS] #1791166
03/29/15 02:23 PM
03/29/15 02:23 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
The best bet is to get the K-member modified and use true Hemi mounts....Any conversion mount has additional headaches to go with it.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: hemi blk to wedge motor mounts? [Re: KOS] #1791167
03/29/15 02:34 PM
03/29/15 02:34 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
The easiest way to swap in a Hemi is Schumacher Creative Services, Sschumacher engine swap mounts.
The engine may sit a small amount higher than stock but mine fits under the hood in mine with no clearance problems.
http://www.engine-swaps.com/Pages/ProductsYear/66.72bBody.html
Re: hemi blk to wedge motor mounts? [Re: HemiRick] #1791168
03/29/15 02:43 PM
03/29/15 02:43 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
If you're wanting it to look perfectly stock using the factory parts are the best choice, but far more expensive.
If you're running any type of factory air grabber set up the factory parts you're usually better off with factory mount parts.
That way all your air grabber parts line up correctly.
For a modified car the Schumacher mounts will do the job just fine.
That's what's I used in mine, no fitment/clearance issues.
Re: hemi blk to wedge motor mounts? [Re: SNK-EYZ] #1791169
03/29/15 02:49 PM
03/29/15 02:49 PM
K
KOS Offline OP
KOS  Offline OP
K
thx for the reply and pix guys.......anyone have pix of factory hemi motor mounts?
Re: hemi blk to wedge motor mounts? [Re: KOS] #1791170
03/29/15 02:53 PM
03/29/15 02:53 PM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
Have the conversion mounts on the wife 74 challenger. No problem with them and a very nice part
If ya want to burn ya money. Go ahead and spend 500-1000 bucks on a k frame
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: hemi blk to wedge motor mounts? [Re: KOS] #1791171
03/29/15 02:58 PM
03/29/15 02:58 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
Re: hemi blk to wedge motor mounts? [Re: SNK-EYZ] #1791172
03/29/15 02:59 PM
03/29/15 02:59 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
Re: hemi blk to wedge motor mounts? [Re: SNK-EYZ] #1791173
03/29/15 03:13 PM
03/29/15 03:13 PM
K
KOS Offline OP
KOS  Offline OP
K
thx again guys one thing that i got to mention is this is a wedge motor with hemi mounting......wonder if headers are an issue with the conversion mounts???and external oiling also.........
Re: hemi blk to wedge motor mounts? [Re: KOS] #1791174
03/29/15 03:19 PM
03/29/15 03:19 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
It depends on what type of external oiling you'd talking about.
Mine has an external swinging pickup in the pan but uses a stock style pump (M/Perf, World block) that has the AN fitting on the front up the block.
Re: hemi blk to wedge motor mounts? [Re: toplescuda] #1791175
03/29/15 07:12 PM
03/29/15 07:12 PM
Tennessee
Hemi ragtop Offline
Hemi ragtop  Offline
Tennessee
Better double that for the mounts to go on the k frame. Shumaker works fine for me for under $300
Re: hemi blk to wedge motor mounts? [Re: Hemi ragtop] #1791176
03/29/15 07:19 PM
03/29/15 07:19 PM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
I bought my conversion mounts for 250.00. I wasnt about to spend big money for a hemi k frame
1971 charger
Re: hemi blk to wedge motor mounts? [Re: toplescuda] #1791177
03/29/15 07:47 PM
03/29/15 07:47 PM
beedees Offline
beedees  Offline
FWIW, the old DC (black cover ) chassis mod. manual had direction for converting a /6 k-frame to hemi mounts. Worked fine, but this was 25-30 yrs. ago.
