Re: 6.4 Hemi in my Cuda?
[Re: BB70DUSTER]
#1790410
03/28/15 07:24 PM
03/28/15 07:24 PM
Posts: 632 Casco, MI
Savoy1964
Casco, MI
There is a Fast N Loud episode on Monday installing one in a 71 Challenger.
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph 2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
[Re: Savoy1964]
#1790411
03/28/15 08:28 PM
03/28/15 08:28 PM
Posts: 4,436 SO CAL
BB70DUSTER
SO CAL
no thanks... TV is just that...
[Re: BB70DUSTER]
#1790412
03/28/15 09:36 PM
03/28/15 09:36 PM
Savoy1964
Casco, MI
you would need a controller. , 6.1 intake and have it CNC to fit 6.4, fuel rails for 6.1, ATI Super Damper is recommended, and Ported 87mm throttle body.
[Re: BB70DUSTER]
#1790414
03/28/15 10:46 PM
03/28/15 10:46 PM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
Why a 6.1 intake?
I believe it has something to do with the fuel system or the fuel rails. The other alternative is finding an early 5.7L intake from a car.
As far as swapping, the typical off the top of my head... TTi mounts, TTi headers, a fuel management system, a small block bellhousing, and a special clutch (idk who makes one).
[Re: MuuMuu101]
#1790415
03/28/15 11:35 PM
03/28/15 11:35 PM
Savoy1964
Casco, MI
6.4 intake has a computer controlled runner that no one has a controller for.
[Re: Savoy1964]
#1790417
03/29/15 12:06 AM
03/29/15 12:06 AM
Posts: 4,436 SO CAL
BB70DUSTER
SO CAL
if I'm reading right that just takes a Rpm activated switch to control it?
[Re: Devil]
#1790425
03/29/15 01:46 PM
03/29/15 01:46 PM
Posts: 3,712 Sacramento, Ca
Darius
Sacramento, Ca
Do not fall into the "this is an easy swap" mentality. There are so many computer issues depending on which engine, trans, instruments, etc you can easily end up spending many times more than you planned. I HIGHLY suggest you talk to Dave at Modern Muscle at the very least. He does this every day across many combinations of platforms. It will NOT be cheap no matter what you think. The least expensive way is to get the info up front and proceed accordingly. Sure, there is a lot of info about how to make it all fit...that is the EASY part! Been there and done all of that and that is where I am coming from. The computer issue is huge on these swaps particularly when you don't have it figured out up front. Progress is being made daily on making these swaps easier.
Driving modern convenience in classic beauty
