1973 dodge charger fender question #179026
12/30/08 06:04 PM
12/30/08 06:04 PM
las vegas, nevada
bugsydog Offline OP
bugsydog  Offline OP
las vegas, nevada
I found a fender for my 73 charger, but it has the chrome piece that bolts to the front of the fender were the bumper is. My 73 charger does not have this piece, the question if i remove the chrome piece will it match the other fender or will i need to find another fender?
Re: 1973 dodge charger fender question [Re: bugsydog] #179027
12/30/08 06:08 PM
12/30/08 06:08 PM
MOPAR HEADQUARTERS IN ALDEN NY
hemigod426 Offline
hemigod426  Offline
just make sure its not a 72 fender and it will be fine, was it se cars had diecast filler and non se cars had rubber bumber filler
MOPAR OR NO CAR
Re: 1973 dodge charger fender question [Re: bugsydog] #179028
12/30/08 06:15 PM
12/30/08 06:15 PM
las vegas, nevada
bugsydog Offline OP
bugsydog  Offline OP
las vegas, nevada
these fenders are from an SE car 1974, my car is a 73 and never had any type of fillers.
Re: 1973 dodge charger fender question [Re: bugsydog] #179029
12/30/08 10:45 PM
12/30/08 10:45 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
we have to make difference on this... one thing is the FILLER what is a rubber piece attached to bumper and the other thing is the molding trim attached to fender what with a minimal and unnapreciable difference between pieces for 71/72 and 73/74 they fit the same on any year
Fillers were just to 73/74 no matter model
Molding trims were standart on SEs and I think optional on the rest.
They fit on same fender, so that trim makes not difference on fender... only diff could it be some holes to attach the trim, what if they are visible, will need to be filled if wished BUT 73/74 bumper fillers should cover those holes, so is not really a problem I think
Re: 1973 dodge charger fender question [Re: bugsydog] #179030
12/30/08 11:02 PM
12/30/08 11:02 PM
las vegas, nevada
bugsydog Offline OP
bugsydog  Offline OP
las vegas, nevada
I don't want the SE trim on the fender, i need it to match the other fender, my car is not an SE model, but if i remove the trim then the holes will be noticable right?
Re: 1973 dodge charger fender question [Re: bugsydog] #179031
12/30/08 11:05 PM
12/30/08 11:05 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
maybe not because bumper filler should cover them...
anyway, is not a big deal... since I guess you have to paint the fender, fill the holes on that moment and done!
