Re: 1973 dodge charger fender question
[Re: bugsydog]
#179029
12/30/08 10:45 PM
12/30/08 10:45 PM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
we have to make difference on this... one thing is the FILLER what is a rubber piece attached to bumper and the other thing is the molding trim attached to fender what with a minimal and unnapreciable difference between pieces for 71/72 and 73/74 they fit the same on any year
Fillers were just to 73/74 no matter model
Molding trims were standart on SEs and I think optional on the rest.
They fit on same fender, so that trim makes not difference on fender... only diff could it be some holes to attach the trim, what if they are visible, will need to be filled if wished BUT 73/74 bumper fillers should cover those holes, so is not really a problem I think
[Re: bugsydog]
#179031
12/30/08 11:05 PM
12/30/08 11:05 PM
NachoRT74
Valencia, España
maybe not because bumper filler should cover them...
anyway, is not a big deal... since I guess you have to paint the fender, fill the holes on that moment and done!
