Dakota fender interchangability? #1789605
03/27/15 08:34 PM
03/27/15 08:34 PM
Between Houston & Galveston TX
SattyNoCar Offline OP
Went by the Pick-N-Pull in Pasadena today.....
Apparently one of the oil refineries turned in their fleet of trucks. Aside from this line of Dakotas, there were at least double this amount scattered thru the yard. Interiors are beyond trashed on all of 'em, but, quite a few still have good body panels.
All are '89-'91 vintage.
My question is, is there a difference in the fender of a '91 that has the sealed beam head light rather than the areo one?
How about the radiator support? Can an aero headlight be installed in a rad support that had a sealed beam mounted to it?
Mine is smacked on the left front corner. I haven't pulled it apart yet to see the extent of the damage but, I'm thinking the rad support may need to be swapped too.
(OR, would you pony up a few more dollars and just buy a new fender?)
As usual, thanks!
John
Re: Dakota fender interchangability? [Re: SattyNoCar] #1789606
03/27/15 08:42 PM
03/27/15 08:42 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I don't know about the deatails of interchangabiity but I would take my time and find one the right color from the factory so I did not have to paint it and have one shiny fender on an old dull truck.
Re: Dakota fender interchangability? [Re: HotRodDave] #1789607
03/27/15 08:56 PM
03/27/15 08:56 PM
The pictures of my truck hide a LOT. My truck needs a repaint (brush and roll? ), so, I'm not too concerned about it matching.
The roof on mine for example (and its been repainted at least once already)..
Re: Dakota fender interchangability? [Re: SattyNoCar] #1789608
03/27/15 10:56 PM
03/27/15 10:56 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I believe in 92 Dodge extended the nose out to make more room for the V8. I think the fenders are the same 87-96, but the bumper & grill extend farther forward then the 87-91 grills. I suspect the rad support is likely different between the two series, but with a V6, the complete nose from the older trucks might bolt on to your truck. There might be wiring changes between the two series as well (not that that would matter to you), didn't the OB II come out around 92 or 93 as well? Gene
Re: Dakota fender interchangability? [Re: poorboy] #1789609
03/28/15 11:56 AM
03/28/15 11:56 AM
places
79powerwagon Offline
places
OBDII was later (1996 if I recall right, my 97 needs emission testing and that requires OBDII).
Dodge didn't have a bunch of money for tooling, I'd suspect the older fenders and parts are the same basic shape and size to each other, with perhaps feature details being different (bolt hole locations, that kind of thing). And Dakotas came with inline 4's, so a V8 isn't much of a stretch, length wise.
Re: Dakota fender interchangability? [Re: 79powerwagon] #1789610
03/28/15 03:32 PM
03/28/15 03:32 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Our local U pick it has an interchange in the office. Use that to confirm. That way if it doesn't bolt up, they are more likely to exchange/refund.
I'd grab a bunch of sensors, look over service items and if they appear recent, grab them too if they are pennies on the dollar.
Re: Dakota fender interchangability? [Re: RodStRace] #1789611
03/28/15 05:07 PM
03/28/15 05:07 PM
New Brunswick, Canada
TrxR Offline
TrxR  Offline
As far as aftermarket is concerned they use the same part number from 86 to 96.
Re: Dakota fender interchangability? [Re: RodStRace] #1789612
03/28/15 05:09 PM
03/28/15 05:09 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
The flat nose Dakotas and the round nose share fenders, but the hoods, radiator supports, bumpers, and grille assembly are different between them.
If you have a V8 you cannot put a flat nose on without mods to the fan assembly on the waterpump.
If they have any with a good clean, and solid rear bumper I would be interested in one if it could be shipped. I would prefer a painted bumper over chrome, but as long as its straight, and not rotted out I would be interested in a quote.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: Dakota fender interchangability? [Re: hp383] #1789613
03/28/15 05:59 PM
03/28/15 05:59 PM
Thanks for the feedback.
hp383, you have a PM.....
John
