I had this recall done on my truck last December [2007]. A few months ago, I started noticing what sounded like alot of tire noise from the front of the truck. Initially thinking it was the tires, I tried rotating, balancing, tire pressure, etc. It turns out it was a problem with the bearing in the left front hub and the local dealer did the repair as a recall repair.
Since the recall work had [supposedly] been done and I still had a problem, is this something that could keep coming back, or does it mean the recall wasn't done properly the first time?
Thanks for any input.
