Brackets for BB low mount Alt #1788896
03/26/15 05:15 PM
03/26/15 05:15 PM
Lowes
steve660 Offline OP
steve660  Offline OP
Lowes
Need to relocate ( lower) my Alt....does anyone know who makes low mount Alt brackets for BB?? Just need the brackets, already have good Alt. Has anyone tried to mount Alt on DS head??? I may give it a try.
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure.
..... Now its a door stop....
Re: Brackets for BB low mount Alt [Re: steve660] #1788897
03/26/15 05:25 PM
03/26/15 05:25 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Do you have a motor plate? What kind of alternator are you running?
Re: Brackets for BB low mount Alt [Re: steve660] #1788898
03/26/15 05:28 PM
03/26/15 05:28 PM
AndyF Offline
AndyF  Offline
I make a bracket kit to hang a small alternator from the motor plate. Doty makes a low mount kit that hangs from the timing chain cover.
Re: Brackets for BB low mount Alt [Re: steve660] #1788899
03/26/15 06:04 PM
03/26/15 06:04 PM
How about mounting it( make a bracket) off of the power steering pump boss bolt hole on the water pump housing
Re: Brackets for BB low mount Alt [Re: Cab_Burge] #1788900
03/26/15 06:34 PM
03/26/15 06:34 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I have one for sale in the race section, except mines black......It has the optional magnetic pick-up as well.
Re: Brackets for BB low mount Alt [Re: Dragula] #1788901
03/26/15 07:01 PM
03/26/15 07:01 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
I run this same bracket and alt., nice clean setup.
Re: Brackets for BB low mount Alt [Re: Dragula] #1788902
03/26/15 08:04 PM
03/26/15 08:04 PM
Scatchamatoon
Saskabusa Offline
Saskabusa  Offline
Scatchamatoon
I have this one it is great!
1974 Roadrunner
1967 Charger
Re: Brackets for BB low mount Alt [Re: nss guy] #1788903
03/26/15 08:05 PM
03/26/15 08:05 PM
Dragula Offline
Dragula  Offline
Mine won't fit with the way my plate is in the Duster...Mine has tabs for the plate on the inside of the frame rails instead of on top...Really sucks.
Re: Brackets for BB low mount Alt [Re: Dragula] #1788904
03/26/15 08:15 PM
03/26/15 08:15 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Here's AndyF's (AR Engineering) setup, works great.
http://arengineering.com/products/motorplate-kit-powermaster/
My friend and I use a Toyota Denso alternator with this setup and it is by far the best charging system I've ever had.
Re: Brackets for BB low mount Alt [Re: ProSport] #1788905
03/26/15 10:04 PM
03/26/15 10:04 PM
Lowes
steve660 Offline OP
steve660  Offline OP
Lowes
Prosport....Im not running an engine plate....Heres pictures of what im working with. The oil drain lines are in the way. Alternator is a full size 140 amp Powermaster. Only had it 1 year and would rather not have to buy mini one. So I need low mount brackets for a full size alt.
Re: Brackets for BB low mount Alt [Re: steve660] #1788906
03/26/15 10:05 PM
03/26/15 10:05 PM
Lowes
steve660 Offline OP
steve660  Offline OP
Lowes
another
Re: Brackets for BB low mount Alt [Re: steve660] #1788907
03/26/15 10:07 PM
03/26/15 10:07 PM
Lowes
steve660 Offline OP
steve660  Offline OP
Lowes
#2
Re: Brackets for BB low mount Alt [Re: steve660] #1788908
03/26/15 11:42 PM
03/26/15 11:42 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I don't know what kind of car you have or what it was built for but I would strongly consider an AndyF motorplate, they're affordable, practically bolt right in, allows more header room, and makes life easier for mounting an alternator, coil, etc.
I have one installed in my Duster and it will probably never see a race track, it just made everything easier to go that route.
Re: Brackets for BB low mount Alt [Re: ProSport] #1788909
03/26/15 11:49 PM
03/26/15 11:49 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
2
Re: Brackets for BB low mount Alt [Re: ProSport] #1788910
03/26/15 11:51 PM
03/26/15 11:51 PM
5th and plum
redmist Offline
redmist  Offline
5th and plum
I think I am going to get one of these low mount kits, to make room for a procharger on the passenger side. I want to keep my power steering!
Re: Brackets for BB low mount Alt [Re: steve660] #1788911
03/27/15 12:02 AM
03/27/15 12:02 AM
AndyF Offline
AndyF  Offline
Why not move the oil line a little bit? Looks to me that you could rotate the oil line just a little bit to make room for the alternator.
Re: Brackets for BB low mount Alt [Re: AndyF] #1788912
03/27/15 12:18 AM
03/27/15 12:18 AM
Lowes
steve660 Offline OP
steve660  Offline OP
Lowes
That might work!!! Ill check it out. Thanks Andy!!!
Re: Brackets for BB low mount Alt [Re: steve660] #1788913
03/27/15 07:27 AM
03/27/15 07:27 AM
VA.
mosweethemi Offline
mosweethemi  Offline
VA.
Hello I have a 1973 pro street Duster with a motor plate .I got mine form Mancini Racing . works great .I think it was about $102.95 plus shipping .
Re: Brackets for BB low mount Alt [Re: steve660] #1788914
03/27/15 08:02 PM
03/27/15 08:02 PM
AndyF Offline
AndyF  Offline
You should be able to rotate the oil line out towards the header just enough to miss the alternator without getting into the headers. At least that is how it looks in the picture. Not sure if you have anything else in that area. You might need to get another line built that is a couple of inches longer but that would be cheaper than building a custom alternator bracket or a new alternator.
