Brackets for BB low mount Alt
#1788896
03/26/15 05:15 PM
03/26/15 05:15 PM
Posts: 289 Lowes
steve660
Lowes
Need to relocate ( lower) my Alt....does anyone know who makes low mount Alt brackets for BB?? Just need the brackets, already have good Alt. Has anyone tried to mount Alt on DS head??? I may give it a try.
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure. ..... Now its a door stop....
Re: Brackets for BB low mount Alt
[Re: Dragula]
#1788901
03/26/15 07:01 PM
03/26/15 07:01 PM
Posts: 1,442 central ohio
nss guy
central ohio
I have one for sale in the race section, except mines black......It has the optional magnetic pick-up as well.
I run this same bracket and alt., nice clean setup.
[Re: nss guy]
#1788903
03/26/15 08:05 PM
03/26/15 08:05 PM
Posts: 12,386 Taxes & Virus's R-US, NY
Dragula
Mine won't fit with the way my plate is in the Duster...Mine has tabs for the plate on the inside of the frame rails instead of on top...Really sucks.
[Re: ProSport]
#1788905
03/26/15 10:04 PM
03/26/15 10:04 PM
Posts: 289 Lowes
steve660
Lowes
Prosport....Im not running an engine plate....Heres pictures of what im working with. The oil drain lines are in the way. Alternator is a full size 140 amp Powermaster. Only had it 1 year and would rather not have to buy mini one. So I need low mount brackets for a full size alt.
[Re: steve660]
#1788908
03/26/15 11:42 PM
03/26/15 11:42 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
I don't know what kind of car you have or what it was built for but I would strongly consider an AndyF motorplate, they're affordable, practically bolt right in, allows more header room, and makes life easier for mounting an alternator, coil, etc. I have one installed in my Duster and it will probably never see a race track, it just made everything easier to go that route.
[Re: AndyF]
#1788912
03/27/15 12:18 AM
03/27/15 12:18 AM
Posts: 289 Lowes
steve660
Lowes
That might work!!! Ill check it out. Thanks Andy!!!
