904 Transmission Rear clutch question #1788644
03/26/15 10:35 AM
03/26/15 10:35 AM
Ohio
tiffinohio Offline OP
Ohio
Hello, Upgrading a 1971 904 that is behind a 350+ HP /6. Bored 0.060, milled 0.020 off block and 0.100 off head. Back yard port job, MPFI, and twin 2.0L turbos. Stock cam (not too bad in that year)
I milled the pressure plate on the front clutch set 0.050 to accomodate 4 race clutches in place of the 3 that were stock. I have 0.070 clearance there and think I'm OK. I would like to upgrade the rear clutch drum as well to accomodate 4 frictions in place of the 3 stock but I would have to mill 0.125 off the pressure plate. That seems like a bit much. I went to my bone yard and found out that I cant just put a 4 disk rear drum in as that would require new shaft and pump assy. Does anyone make a thinner/stronger pressure plate? Can I mill that much off w/o major warpage issues? Is it a big deal to leave 3 clutches in the rear drum? Some say its about line pressure not # of clutches, but I'm not so sure. Looking for advice!
Thanks,
Re: 904 Transmission Rear clutch question [Re: tiffinohio] #1788645
03/27/15 09:29 PM
03/27/15 09:29 PM
Wisconsin
beecrazy69 Offline
beecrazy69  Offline
Wisconsin
The best way would be to put v8 parts in it. It has to be the correct year range and or get pump with both drums out of a v8 unit so you don't have to worry about mixing and matching stuff.
A 4 clutch rear drum- 4 will be fine
A 4 clutch front drum- you can use forward (rear clutch) discs to accommodate 5 discs with little machining required.
Good luck!
Re: 904 Transmission Rear clutch question [Re: tiffinohio] #1788646
03/27/15 09:33 PM
03/27/15 09:33 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
How much line pressure you plan on using ?
Re: 904 Transmission Rear clutch question [Re: tiffinohio] #1788647
03/27/15 10:52 PM
03/27/15 10:52 PM
I would have to mill 0.125 off the pressure plate. That seems like a bit much. Looking for advice! Thanks,
Welcome here! How thick is the PP now? Unless someone advized/confirmed otherwise on what to do as is with your /6 innards I'd get a junk v8 904 & at least compare parts.
Re: 904 Transmission Rear clutch question [Re: RapidRobert] #1788648
03/27/15 11:11 PM
03/27/15 11:11 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Be careful, mix and match in a 904 is tricky business. The stack up between the pump, high gear clutch an the splines on the input shaft can result the pump hitting the drum and the last friction in the high clutch jumping off the splines burning up the high gear clutch pack. Don't ask how we know.
Doug
