MAKE IT STEER LIKE IT'S ON RAILS!!!
#1785868
03/22/15 08:06 PM
03/22/15 08:06 PM
Posts: 441 Uranus
strokerchall
Uranus
Just curious if theres a kit to tighten up my steering on a 70 chall,I use to have a 79 trans am that steered sooo nice and i could really drive that thing!!! Currently i have the stock steering box with manual steering which is a lil crazy with the 512 stroker and had a couple near crashes.Also i want to upgrade the braking. Of course the cheapest was would be best but fire away. thanks
once you've stroked it,you'll wish you stroked it sooner
Re: MAKE IT STEER LIKE IT'S ON RAILS!!!
[Re: strokerchall]
#1785870
03/22/15 09:25 PM
03/22/15 09:25 PM
Posts: 96,664 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
Replace the engine, and slow down and it shouldn't crash.
THEN fix the brakes, and it shouldn't crash.
THEN put in a performance steering box.
If it's almost crashed a couple times already, then don't drive it until it's fixed...
brakes, steering, engine, in that order.
Or buy a better driver...
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: amxautox]
#1785871
03/22/15 09:33 PM
03/22/15 09:33 PM
amxautox
Doc Diff can sell you what you need for brakes, front and rear. Borganson Steering Box, or another one of those, can fix your steering problem. A Richard Petty Driving School, or another one of those places, can help with controlling the car.
Tom
author unknown
[Re: amxautox]
#1785872
03/22/15 09:50 PM
03/22/15 09:50 PM
Posts: 441 Uranus
strokerchall
Uranus
nothing to do with the driver,i've been driving like an @[Edited by Moparts - Family Friendly Site - Keep it clean] since i had a license.Had a few fast cars,both times it was a chunk of sh!tty pavement that broke loose and the car went snakey.
Prob spend 2-3k on brakes and steering upgrade,what ya have in mind?
[Re: amxautox]
#1785874
03/23/15 12:00 AM
03/23/15 12:00 AM
Posts: 441 Uranus
strokerchall
Uranus
the hotchkis TVS kit is $3200+ american
[Re: TC@HP2]
#1785887
03/29/15 10:54 PM
03/29/15 10:54 PM
Posts: 2,072 Cambridge, Ontario, Canada
CUDAJAS
...or you have a thrust alignment issue. I'd make sure the rear is square and parallel.
A step up to power steering would be a big help too. You just can't move a manual steering box wheel with those wide front tires fast enough when it starts getting away from you.
Man isn't that the truth!!
I went to power from manual on my Cuda last year and it is the single best improvement I have made.
manual box is 5 1/2 turns lock to lock, and power is 3 1/2 turns. That is a huge difference.
Other then that I would ensure that none of the suspension components are worn out and go from there.
Jason
