MAKE IT STEER LIKE IT'S ON RAILS!!! #1785868
03/22/15 08:06 PM
03/22/15 08:06 PM
Uranus
strokerchall Offline OP
Uranus
Just curious if theres a kit to tighten up my steering on a 70 chall,I use to have a 79 trans am that steered sooo nice and i could really drive that thing!!! Currently i have the stock steering box with manual steering which is a lil crazy with the 512 stroker and had a couple near crashes.Also i want to upgrade the braking.
Of course the cheapest was would be best but fire away.
thanks
once you've stroked it,you'll wish you stroked it sooner
Re: MAKE IT STEER LIKE IT'S ON RAILS!!! [Re: strokerchall] #1785869
03/22/15 09:21 PM
03/22/15 09:21 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
What's the budget?
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: MAKE IT STEER LIKE IT'S ON RAILS!!! [Re: strokerchall] #1785870
03/22/15 09:25 PM
03/22/15 09:25 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
Replace the engine, and slow down and it shouldn't crash.
THEN fix the brakes, and it shouldn't crash.
THEN put in a performance steering box.
If it's almost crashed a couple times already, then don't drive it until it's fixed...
brakes, steering, engine, in that order.
Or buy a better driver...
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: MAKE IT STEER LIKE IT'S ON RAILS!!! [Re: amxautox] #1785871
03/22/15 09:33 PM
03/22/15 09:33 PM
amxautox Offline
amxautox  Offline
Doc Diff can sell you what you need for brakes, front and rear.
Borganson Steering Box, or another one of those, can fix your steering problem.
A Richard Petty Driving School, or another one of those places, can help with controlling the car.
Tom
author unknown
Re: MAKE IT STEER LIKE IT'S ON RAILS!!! [Re: amxautox] #1785872
03/22/15 09:50 PM
03/22/15 09:50 PM
Uranus
Uranus
nothing to do with the driver,i've been driving like an @[Edited by Moparts - Family Friendly Site - Keep it clean] since i had a license.Had a few fast cars,both times it was a chunk of sh!tty pavement that broke loose and the car went snakey.
Prob spend 2-3k on brakes and steering upgrade,what ya have in mind?
Re: MAKE IT STEER LIKE IT'S ON RAILS!!! [Re: strokerchall] #1785873
03/22/15 10:03 PM
03/22/15 10:03 PM
amxautox Offline
amxautox  Offline
Ya, chunks of asphalt will screw up anybody's straight course.
Tom
author unknown
Re: MAKE IT STEER LIKE IT'S ON RAILS!!! [Re: amxautox] #1785874
03/23/15 12:00 AM
03/23/15 12:00 AM
Uranus
Uranus
the hotchkis TVS kit is $3200+ american
Re: MAKE IT STEER LIKE IT'S ON RAILS!!! [Re: strokerchall] #1785875
03/23/15 12:17 AM
03/23/15 12:17 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Thorough check of every suspension component for wear and breakage.
Firm Feel firm power steering box and Saginaw power steering pump.
Performance alignment with 1/2 neg camber, 3-5 deg pos caster, 1/16 toe in.
Next step up in $$ would be Borgenson power steering box conversion.
Re: MAKE IT STEER LIKE IT'S ON RAILS!!! [Re: strokerchall] #1785876
03/23/15 01:48 AM
03/23/15 01:48 AM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
What size wheels and tires are you running in the front? Skinny, tall tires may make it difficult to control that big block.
Re: MAKE IT STEER LIKE IT'S ON RAILS!!! [Re: MuuMuu101] #1785877
03/23/15 02:59 AM
03/23/15 02:59 AM
Uranus
Uranus
bfg's 265 rear,245 front
Re: MAKE IT STEER LIKE IT'S ON RAILS!!! [Re: strokerchall] #1785878
03/23/15 10:25 AM
03/23/15 10:25 AM
Houston Tx
Uhcoog1 Offline
Uhcoog1  Offline
Houston Tx
Stickier tires front and rear. Borgeson box from Bergman autocraft to speed up the steering. brake pad upgrade. Front sway bar from Hellwig. More aggressive alignment (Steve's specs above will work).
That should suffice if you're not doing much more than street driving.
-'02 Dodge Viper Ex-World Challenge racecar
-'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
Re: MAKE IT STEER LIKE IT'S ON RAILS!!! [Re: Uhcoog1] #1785879
03/23/15 03:13 PM
03/23/15 03:13 PM
Fly Over States
P
PHJ426 Offline
PHJ426  Offline
P
Fly Over States
Don't need to wind up like this Chally ....know when to lift.
Check out this item I found on eBay: http://pages.ebay.com/motors/link/?nav=item.view&id=391089975994&alt=web
Re: MAKE IT STEER LIKE IT'S ON RAILS!!! [Re: PHJ426] #1785880
03/23/15 10:48 PM
03/23/15 10:48 PM
Uranus
Uranus
the azz end kicks out to the right also,it doesn't launch perfectly str8.As you can imagine with a 512, 2800 stahl and 4:10 gears all hell breaks loose when the go pedal meets the carpet
Re: MAKE IT STEER LIKE IT'S ON RAILS!!! [Re: PHJ426] #1785881
03/23/15 11:40 PM
03/23/15 11:40 PM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
5g's just for the front end with no engine, dash, spindles ect? the guy is on glue
Re: MAKE IT STEER LIKE IT'S ON RAILS!!! [Re: dangina] #1785882
03/25/15 12:45 AM
03/25/15 12:45 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Are you looking to retain a manual steering setup? Everyone has made mention of power steering upgrades but what is the OP doesn't want that, or can fit it.
Flaming River used to offer a 16 to 1 chuck. It is cast iron so it looks nothing like the stock one.
Re: MAKE IT STEER LIKE IT'S ON RAILS!!! [Re: Kern Dog] #1785883
03/25/15 05:21 PM
03/25/15 05:21 PM
Uranus
Uranus
would like to hard power steering/fast ratio and tighten up the steering,it's just a little crazy to recover when the car wants to dance.
Re: MAKE IT STEER LIKE IT'S ON RAILS!!! [Re: strokerchall] #1785884
03/25/15 09:06 PM
03/25/15 09:06 PM
Ontario,Canada
brads70 Offline
brads70  Offline
Ontario,Canada
I have one of DrDiff's dana 60's with a tru trac set up. Sounds like this would help your situation. I'm amazed how well it works and goes straight even when the tires are up in smoke. I wonder if something is worn out in your rear end?
Re: MAKE IT STEER LIKE IT'S ON RAILS!!! [Re: brads70] #1785885
03/25/15 11:59 PM
03/25/15 11:59 PM
Uranus
Uranus
I have one of DrDiff's dana 60's with a tru trac set up. Sounds like this would help your situation. I'm amazed how well it works and goes straight even when the tires are up in smoke. I wonder if something is work out in your rear end?
i am considering a tru trac actually,this chunk was rebuilt 742 case 4:10
Re: MAKE IT STEER LIKE IT'S ON RAILS!!! [Re: strokerchall] #1785886
03/26/15 11:58 AM
03/26/15 11:58 AM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
...or you have a thrust alignment issue. I'd make sure the rear is square and parallel.
A step up to power steering would be a big help too. You just can't move a manual steering box wheel with those wide front tires fast enough when it starts getting away from you.
Re: MAKE IT STEER LIKE IT'S ON RAILS!!! [Re: TC@HP2] #1785887
03/29/15 10:54 PM
03/29/15 10:54 PM
Cambridge, Ontario, Canada
CUDAJAS Offline
CUDAJAS  Offline
Man isn't that the truth!!
I went to power from manual on my Cuda last year and it is the single best improvement I have made.
manual box is 5 1/2 turns lock to lock, and power is 3 1/2 turns. That is a huge difference.
Other then that I would ensure that none of the suspension components are worn out and go from there.
Jason
