Rear body&frame improvements
#1784728
03/21/15 09:18 AM
03/21/15 09:18 AM
Posts: 3,575 The Netherlands
BigBlockMopar
The Netherlands
Most of the handling improvements focus on the front and center of the car where most of the action is, but (short of installing a rollbar/cage) I like to see some inputs about improving the body/frame stiffness on the rear of the car. Partly reason for asking is my own car has some sheetmetal rust-issues at the rear which I'm fixing as time permits, but over time I noticed (duh) how quickly the body structure becomes weaker because of this. Letting me to think even a stock (rustfree) body is just marginally sound to begin with. Like, when I'm in the process of parking my car over a heavily crowned roadsurface and wheel on a curb, or when slowly avigating a speedbump at a sharp angle, I can sometimes actually hear the body structure 'work' at the rear because of the rearaxle and leafsprings putting more and less strain on the suspension-mountings. I'm thinking, for instance, just like the beefy lower radiator supportkits available, the rear of the body could use some similar improvements aswell. What say you? Or, is my car really just a turd waiting to crumble and fall apart...
Re: Rear body&frame improvements
[Re: RylisPro]
#1784731
03/21/15 12:58 PM
03/21/15 12:58 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
When I installed my ATL fuel cell I had a fuel cell cage built out of 1x1 inch (25mm x 25mm) square tubing grafted on two 2x2 inch (50mm x 50mm) square tubing running across the frame rails. It really stiffens things up back there
Pics? I'm intended to use a modified stock tank, but am curious on how yours was executed.
[Re: BigBlockMopar]
#1784733
03/21/15 01:24 PM
03/21/15 01:24 PM
Posts: 22,696 Bitopia
jcc
Bitopia
Not sure in daily drivers there is a lot to be gained back there relative to efforts spent at the front, IMO. Some of what I did can be seen starting at Pic #14 https://board.moparts.org/ubbthreads/show...part=1&vc=1
[Re: jcc]
#1784734
03/21/15 01:42 PM
03/21/15 01:42 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Nice work, did you make the recessed battery tray, or what that a purchased part?
[Re: BigBlockMopar]
#1784736
03/22/15 01:02 AM
03/22/15 01:02 AM
Posts: 240 Plano, Texas
68cuda440
Plano, Texas
I did some 1x2 structure to support my aftermarket fabricated tank.
Michael
1968 Barracuda Notchback Coupe
440 EFI 6-pack, T56 Magnum 6-spd
