Rear body&frame improvements #1784728
03/21/15 09:18 AM
03/21/15 09:18 AM
The Netherlands
BigBlockMopar Offline OP
The Netherlands
Most of the handling improvements focus on the front and center of the car where most of the action is, but (short of installing a rollbar/cage) I like to see some inputs about improving the body/frame stiffness on the rear of the car.
Partly reason for asking is my own car has some sheetmetal rust-issues at the rear which I'm fixing as time permits, but over time I noticed (duh) how quickly the body structure becomes weaker because of this. Letting me to think even a stock (rustfree) body is just marginally sound to begin with.
Like, when I'm in the process of parking my car over a heavily crowned roadsurface and wheel on a curb, or when slowly avigating a speedbump at a sharp angle, I can sometimes actually hear the body structure 'work' at the rear because of the rearaxle and leafsprings putting more and less strain on the suspension-mountings.
I'm thinking, for instance, just like the beefy lower radiator supportkits available, the rear of the body could use some similar improvements aswell.
What say you?
Or, is my car really just a turd waiting to crumble and fall apart...
Re: Rear body&frame improvements [Re: BigBlockMopar] #1784729
03/21/15 09:27 AM
03/21/15 09:27 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I was thinking about this the other day and will need to take a look at things. At least on my e-body, things are pretty tight back there with the fuel system wanting to take a bunch of real estate. The shock crossmember is the best thing going back there, perhaps it can be improved upon, boxed, reinforced.
While your rust is reducing it's rigidity, it is a form of active light weighting too.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Rear body&frame improvements [Re: BigBlockMopar] #1784730
03/21/15 12:40 PM
03/21/15 12:40 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
When I installed my ATL fuel cell I had a fuel cell cage built out of 1x1 inch (25mm x 25mm) square tubing grafted on two 2x2 inch (50mm x 50mm) square tubing running across the frame rails.
It really stiffens things up back there
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Rear body&frame improvements [Re: RylisPro] #1784731
03/21/15 12:58 PM
03/21/15 12:58 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Pics? I'm intended to use a modified stock tank, but am curious on how yours was executed.
2020 RAM 1500
Re: Rear body&frame improvements [Re: GoodysGotaCuda] #1784732
03/21/15 01:07 PM
03/21/15 01:07 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Rear body&frame improvements [Re: BigBlockMopar] #1784733
03/21/15 01:24 PM
03/21/15 01:24 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Not sure in daily drivers there is a lot to be gained back there relative to efforts spent at the front, IMO.
Some of what I did can be seen starting at Pic #14
https://board.moparts.org/ubbthreads/show...part=1&vc=1
Re: Rear body&frame improvements [Re: jcc] #1784734
03/21/15 01:42 PM
03/21/15 01:42 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Nice work, did you make the recessed battery tray, or what that a purchased part?
2020 RAM 1500
Re: Rear body&frame improvements [Re: GoodysGotaCuda] #1784735
03/21/15 01:52 PM
03/21/15 01:52 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Thanks, I built three, of different depths, for my different cars, weight lower is always better
Re: Rear body&frame improvements [Re: BigBlockMopar] #1784736
03/22/15 01:02 AM
03/22/15 01:02 AM
Plano, Texas
68cuda440 Offline
68cuda440  Offline
Plano, Texas
I did some 1x2 structure to support my aftermarket fabricated tank.
Michael 1968 Barracuda Notchback Coupe 440 EFI 6-pack, T56 Magnum 6-spd
Re: Rear body&frame improvements [Re: BigBlockMopar] #1784737
03/22/15 12:09 PM
03/22/15 12:09 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Pretty sure if you are hearing things your problem is elsewhere. I'd go over the rear suspension and make sure nothing is sloppy, wore out, or rubbing at extreme angles.
I'd work on chassis improvement front to rear, what happens if the rear is stiffer than the front?
Bad things.
Don't be the exception.
Re: Rear body&frame improvements [Re: Supercuda] #1784738
03/22/15 12:32 PM
03/22/15 12:32 PM
Rescue CA.
joes68340s Offline
joes68340s  Offline
Rescue CA.
Ive owned a few E bodies and they have been pretty sound but then I purchased what was supposed to be my last car dream car. AAR Cuda It has every E body flaw known to man the rear upper shock mount has cracks and flexes the lower front frame rails have issues. So anything you can do to repair or replace and reinforce is going to make it a better car.
Re: Rear body&frame improvements [Re: joes68340s] #1784739
03/23/15 06:50 AM
03/23/15 06:50 AM
The Netherlands, OV
dickdale Offline
dickdale  Offline
The Netherlands, OV
Herman, a while back I found these pictures of reinforcing the rear:
Re: Rear body&frame improvements [Re: dickdale] #1784740
03/23/15 07:37 PM
03/23/15 07:37 PM
The Netherlands
The Netherlands
A-bodies are a little different in that area. The rear shackles are much closer to the rear of the car.
I think I will want to beef up the rear crossmember and perhaps add/beef up the crosssection near the upper shockmounts.
And of course fix the rust in the outer sheetmetal.
Re: Rear body&frame improvements [Re: dickdale] #1784741
03/23/15 07:56 PM
03/23/15 07:56 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
With the extra propane(?) tank you're carrying in the rear, I don't doubt you hear some creaking and groaning going on. If I recall, you've added something like 300# to the trunk. What the actually translates to for stresses in your vehicle, I'm not sure, but I bet you could use a few extra gussets here and there. Rear torque boxes at least and maybe a some extra brackets around the shock bracket.
Gotta say, I've never seen a car tear up the shackle area, so not sure how much of an improvement those would yield.
Re: Rear body&frame improvements [Re: TC@HP2] #1784742
03/23/15 08:07 PM
03/23/15 08:07 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
My thinking, any past rear shackles is only for impact protection.
Re: Rear body&frame improvements [Re: jcc] #1784743
03/23/15 08:22 PM
03/23/15 08:22 PM
The Netherlands
The Netherlands
The rearcross member, to me, has about the same function as the lower radiator support; Keeping the frame rails located in one plane.
Especially when one springpack is pushing harder on the body then the other side, like when cornering.
Re: Rear body&frame improvements [Re: BigBlockMopar] #1784744
03/24/15 02:04 PM
03/24/15 02:04 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Yes we agree, however the rear bumper for example also to some degree does the same thing, the point is, if its past the rear shackles, it does a poorer job of stiffening and a better job of impact resistance, relative to its distance from the shackles.
Re: Rear body&frame improvements [Re: jcc] #1784745
03/24/15 04:08 PM
03/24/15 04:08 PM
Santa Fe Springs, CA
Dan@Hotchkis Offline
We've had our fair share of issues with the rear cross brace.
And we've R&D'd a pretty good solution....
We've done initial testing on 68-72 B Bodies and E Bodies. Works great so far.
Re: Rear body&frame improvements [Re: Dan@Hotchkis] #1784746
03/24/15 04:43 PM
03/24/15 04:43 PM
Rescue CA.
joes68340s Offline
joes68340s  Offline
Rescue CA.
Dan any time frame when that will be available.
Re: Rear body&frame improvements [Re: Dan@Hotchkis] #1784747
03/24/15 04:51 PM
03/24/15 04:51 PM
Gilroy,CA.
mopardude318 Offline
Gilroy,CA.
PLEASE make one for an A-body! I'd buy one! And please don't say an A-body is not worthy! Then We are our own worst enemy
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
